I have a new corel video studio pro x3,when i try tu capture analog from a VHSplayer, comes up saying can not start capture graph,could someone help to wat I need to do?
There´s a problem with CVSX3. The analogic capture is broken. No way to solve this.
Try a Power Director 9, work for all captures devices (USB, DV, PCI, PCI-e, FIREWIRE, WEBCAM...), record up 25.000 btr on MPEG 2 choice.
In Corel Forum, there is a poll about it, "who uses analog capture?"Last edited by Cauptain; 21st Jan 2011 at 06:58.
Yes, capture has been problematic for VideoStudio since version 11. This is a known problem. Until it's solved you would have to use other methods.
Nevertheless, I never believe capturing should be done with an editor. Use a lighter utility that doesn't hog as many resources.
What type of capture, card or tool are you using? If you're simply using firewire and DV, just use WinDV, which is free and very reliable, then input your files into VS for editing.I hate VHS. I always did.
DV Capture Problem
By sailworkless in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 22nd Sep 2011, 09:14 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
VHS Capture Problem
By sdculp in forum Newbie / General discussionsReplies: 7Last Post: 15th Nov 2008, 08:58 -
Capture Problem
By Driftking978 in forum Capturing and VCRReplies: 5Last Post: 28th Apr 2008, 16:44 -
Capture problem
By jjaha in forum Capturing and VCRReplies: 0Last Post: 9th Mar 2008, 14:08
