When doing the first pass using the Thalen Deshaker in Virtualdub, among others you're given a choice of square pixels, NTSC .912, anamorphic 1.215
If I've got SD 4:3, which should I choose and when would you choose the others?
Deshaker needs to know the PAR so it can do rotation properly.
If your source is NTSC DV, choose .912 (which is the PAR for SD 4:3 DAR).
You would choose anamorphic for NTSC 16:9 DV, or square pixels if you had a square pixel source.
A 4:3 square pixel source (which would have to be something other than DV) also has a frame size with a 4:3 ratio (unlike DV which has 720x480, ie 3:2). -
Assuming no resizing has been done in the conversion (frame size is 720x480), then 0.912 would still apply.
conversion square to non square pixels???
By jakeotr in forum Video ConversionReplies: 7Last Post: 27th Jan 2012, 00:53 -
Square pixels or 16:9 Pixel aspect ratio?
By Scherwin in forum Video ConversionReplies: 6Last Post: 18th May 2010, 12:47 -
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 02:56 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 10:20 -
should use square pixels or not for 16:9?
By j.man in forum Video ConversionReplies: 5Last Post: 4th Mar 2008, 21:28
