Hi, I'll try to keep this short and sweet..
I am using Sony Vegas Pro 10, and I have 3 layers.. 2 (grouped) are a video/audio layer (Wii recordings from Avermedia HD DVR) and the third layer is my commentary captured from a Blue Snowball USB Microphone. In the preview and in the timeline, the sound is synched perfectly..as soon as I try to render it (I've tried MANY different settings and filetypes) the sound and video go out of synch! My voice and the sound from the game ARE in synch with eachother, but the video is not in synch. It appears further down in the video (say at the 10 min mark) the more out of synch it gets. The video is more ahead of the sound, it seems.
How can I fix this? I posted on another forum, and the best I got was to render both separately, then mux them together.. It might work but it's far too time consuming to do that when I am trying to do a whole bunch of "episodes"
I am looking for a more permanent solution.. I am sure it's something simple, some setting or something.. anyway, thanks for reading and for any help!![]()
it usually happens when the audio is recorded using vbr or the video being used is vfr.
In that case, you can open the audio from the timeline into Sound Forge and convert to WAV, then it will come back into the project as "Take 2".
Right-click the audio and "open with...".
Not sure if it works with Audacity. -
audio 48 Khz= video delayed
audio 32 Khz= Not delayed
Render with 32 Khz audio
Reply if ok or not.
It was ok for me.
How to render in sony vegas pro 11?
By skorpinok in forum Video ConversionReplies: 3Last Post: 7th Jan 2012, 09:05 -
Cut
By AndreaRoviso in forum EditingReplies: 0Last Post: 15th Aug 2011, 16:52 -
sony vegas pro 8 rendering wont render video just audio and text
By bahlue18 in forum EditingReplies: 6Last Post: 12th Apr 2011, 07:31 -
Best render for 4:3 video using Sony Vegas pro 10 for youtube
By fuzzblaster in forum Video ConversionReplies: 0Last Post: 9th Jan 2011, 13:18 -
Sony Vegas Pro 9 Render Settings?
By Wickwire in forum Video Streaming DownloadingReplies: 8Last Post: 28th Dec 2009, 09:46
