Hello,
I have 7 pc's hooked to my home network. Five are xp machines and two are W7. I can share and move files and folders with all but one. It is a Dell Inspiron laptop. I right clicked on the folders I wanted to share with the XP laptop like all other XP pc's and selected share will all in the settings. The funny thing is I can see it on the network list but I can't access it. What else can I try? Is there a setting I am missing on the laptop? The laptop uses wired ethernet connection most of the time. All of my pc's are wired using 10 gb gigaspeed cable. I can see and move files on the Dell laptop from other pc's. But can't access the laptop from any other pc's.
	try checking your Windows Firewall settings..
 or
 if your using Norton or McAfee... check their settings also
	Also your permission settings may need to be adjusted to allow access. If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
 Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078
	matching accounts on all the computers
 same username and password on each computer
  HDMI through NetworkBy wazza88 in forum DVB / IPTVReplies: 20Last Post: 17th Feb 2011, 18:41
  Using two routers on network... is it possible?By neworldman in forum ComputerReplies: 10Last Post: 14th Jan 2010, 01:25
  Streaming TV Over a network!By Brianmaiden in forum Video Streaming DownloadingReplies: 6Last Post: 16th Nov 2009, 11:19
  Network printer on separate network?By Lucifers_Ghost in forum ComputerReplies: 7Last Post: 5th Dec 2008, 14:52
  Setting up a networkBy bballnut in forum ComputerReplies: 6Last Post: 2nd Jun 2007, 16:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
