Results 1 to 19 of 19
  1. PLEASE HELP!!! I'm so frustrated! I have this new computer (HP with windows 7) and have bought it purposely for burning DVDs. However, one the burning process is complete and I go to watch them, the picture is perfect, but there is no sound! I have made a couple previously which worked ok, but now it seems every one I try to do comes out like that. When I play the same video on my computer, the audio works just fine. I'm using the 'windows dvd maker' program which came pre=installed. What could I be doing wrong?
    Also, I purchased DVD+R discs, with an understanding that if needed, I would be able to re-write them, but after I format the discs which have burnt without the audio (which is what I think you have to do to erase a disc, please correct me if I am wrong!) and I then go to re-use the, an error message comes up telling me that the disc I have inserted is not a blank one. Help please... anybody..? Thanks!
    What do you rip with? Windows dvd maker can't rip. Or are you making dvds from avi/mkv/mp4/etc files?
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You can't re-write DVD+R or DVD-R discs. You need RW discs for that.
    To clarify, you create your DVD in Windows DVD Maker, and when you play it back on your PC it is OK, but when you play it back in a DVD player it has no audio ?
    Or has the audio suddenly stopped playing on your computer ?
    Are you using Windows media Player or something else ? If not something else, try VLC or Media Player Classic Home Cinema and see what happens.
    What is your source ?
    What does mediainfo say about the VOB files on the DVD you created ?
    You could also try AVStoDVD or DVD Flick instead, as these will encode and author a DVD. Burn with Imgburn to create your DVD Video disc.
    Read my blog here.
  4. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Posted to late....
    What We Do In Life, Echoes In Eternity....
  5. Thank you very much for your replies. I have downloaded certain files from bittorent, and also downloaded Divx to watch them. I have already gathered that Divx files cannot be burned through the windows DVD maker, so I try to look for files which can be watched on Windows media player instead. I tried to burn the files on windows media player first, but although the DVD burned, it did not play back on my DVD player, an error message came up. I'm not sure what kind of file the movies are, I know how to use computers but not the technical stuff! All I know is that mp4 files don't work on my dvd player either. My computer came preloaded with cyberlink power DVD9 and DVd suite. I have managed to burn a disk using one of those programs, with which the audio works fine, but whereas with windows DVD maker, my films fit on my DVD disks, on cyberlink, the same film exceeds the disk size. Maybe there is a way to compress the movie? Also, the downloaded film plays fine (with audio) on windows media player, but once the disk is burned and I try to watch it on my dvd player, there is no sound. the same disk plays without sound if I try to watch it on my computer also. Is there a way to fix this? I have tried to play about with the settings, but cannot manage to fix it... I have previously burned a couple which worked, so that's why I don't understand why it's not working now. I have now downloaded Nerolite. Will that help?
    Also, my DVD disks say DVD+R and under in small writing says RW... I thought those were the rewritable ones, no?>
    Thanks guys, I really appreciate your time and help!
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Moving you to our video conversion section as this is not dvd ripping.
    Just use dvd flick, avstodvd or convertxtodvd instead. They are better for avi divx files. Or get a cheap dvd player with divx support.
  7. Oh, I thought it was ripping, I gess it's just burning then lol. Thank you very much for your reply. I will download one of those programs instead. Thank you
  8. Banned
    Freedonia
    You'd have to post a picture for us to be sure, but DVD+RW should say DVD+RW. Not sure without a photo what the small "RW" means.
    You should not have to format DVD+R prior to use.
    Use ImgBurn (it's freeware) for burning for best results. And I recommend not doing multisession burns as few players can see all the sessions. Just burn everything at one time for best results. Use "disc at once" mode if you don't use ImgBurn and your burning program gives you a choice between that and "track at once".
  9. That's excellent, thank you so much for your help. I have downloaded that program now, will give it a try. I tried avstodvd, but the disk I burned on that program didn't playon my dvd player... This is the pic of my dvds. What do you think? RW or not RW? Click image for larger version
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    That is a +R.....NOT an RW disc.
  11. Oh, ok, never mind, thanks for that. By the way, in the video converter, what should I choose for output format? There are so many... Should I choose DVD MPEG 2ps format?
  12. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Which program?
  13. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    ImgBurn doesn't convert video....it just burns. You need to start over and write down the procedures to get a compressed video file to a watchable DVD(that you can watch in you DVD player).
  14. I clicked on the word Imgburn on your message on this site and followed the link tpo download. What I ended up with is a program called videoconverter by Foxtab. From what you are saying to me, it sounds like somehow I downloaded the wrong software. What do you think?
  15. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Click Download - Direct Link
    AND....again....ImgBurn doesn't convert video....it just burns.
    ImgBurn alone will not get the job done.
  16. Thank you for your reply. I have now downloaded Imgburn. Which other program(s) should I download and can you also please go through once how I should use it please? I really appreciate your time and help. Thank you.
  18. Excellet, thank you very much for your help. Take care.
