Can someone tell me how to burn an .avi to work in a dvd player... tried everything and nothing seem to work. what format do you use.. mpeg1 mpeg2. Vcd?? can somone help please i'm going crazy
You can either burn an SVCD if your player supports it or a VCD (Mpeg1).
In case of VCD, you should make sure your player can play CDRs. Otherwise, try CDRWs.
For conversion, look up the conversion/burning guides on this site.
I personally use TMPGENC for conversion to VCD and get very good results. I burn the resulting MPEG1 files on CDrs using Nero and they play well on my Shinco DVD player.
Burning AVI to DVD - AVI not viewable
By Budfudder in forum Video ConversionReplies: 8Last Post: 24th Mar 2011, 09:36 -
Avi burning problems
By blitzen in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2011, 12:09 -
Burning .avi to DVD
By monieeka in forum MacReplies: 6Last Post: 12th Sep 2008, 06:40 -
Burning .avi files
By pilgrim02 in forum MacReplies: 13Last Post: 31st Jul 2007, 11:52 -
AVI to DVD Burning
By DVDHelpPlease in forum Authoring (DVD)Replies: 2Last Post: 3rd Jul 2007, 23:38
