Hi,
I have a program that captures videos streams in asf formats. The files play fine without any issues.
When I try to convert the asf file to any other format (to play on ipod, iphone, psp), I get audio sync problem.
I tried many video converters (super, DVDfab, handbreak, MS movie maker ) and the result is always the same.
Is there a simple way of making the audio sync when converting this file? Do I need to extract the audio first and then add it to the video? Again, this issue happens only when I convert the file. Maybe I need to change some settings when I convert the file?
General
Complete name : C:\an1.asf
Format : Windows Media
File size : 35.1 MiB
Duration : 5mn 34s
Overall bit rate : 880 Kbps
Maximum Overall bit rate : 933 Kbps
Movie name :
Performer :
Video
Format : VC-1
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Duration : 5mn 34s
Bit rate : 805 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.087
Stream size : 32.1 MiB (91%)
Audio
Format : WMA
Format version : Version 2
Codec ID : 161
Codec ID/Info : Windows Media Audio
Duration : 5mn 34s
Bit rate : 32.0 Kbps
Channel(s) : 2 channels
Sampling rate : 32.0 KHz
Bit depth : 16 bits
Stream size : 1.28 MiB (4%)
You could try use asfbin, open the asf and just click cut/copy/join to make a new asf. Then try convert it with latest Xmedia Recode or the apps that you already are using.
Baldrick you are the man....(-:
Xmedia Recode did the trick and I'm not sure why.
The asf files I have been cut before using asfbin. So I did 2 tests. One with the file as is and the second with creating a new asf file from asfbin. Both results (ipod, psp formats) came back with no audio sync what so ever.
Not sure why all the other convertors I used created a AV sync issue.
Thanks again. I will use that tool from now on with asf files.
Cheers -
Evidently, the developers of XMediaRecode read VideoHelp on a daily basis
Thank you El Heggunte. You gave me some good suggestion in the other thread but that was going to be too much work.
This tool (that I never heard off before) made life easier for me. Just one clikc and the file comes out fine with no audio sync issues. The kids are happy that they can watch this on their ipod and I'm happy that I don't have to do much work....
Cheers
How to fix audio sync issue in a wmv file
By pjbarbour in forum AudioReplies: 11Last Post: 20th Nov 2012, 14:29 -
converting asf file audio sync issues
By andy99 in forum Video ConversionReplies: 4Last Post: 21st Jan 2011, 03:09 -
Audio Sync issue?
By tb582 in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2011, 11:25 -
Audio/Video Sync Issue with .mts File Conversion
By arturo_morosoff in forum Video ConversionReplies: 2Last Post: 4th May 2010, 09:52 -
Audio out of Sync Issue.
By DSMKilla in forum Capturing and VCRReplies: 7Last Post: 17th May 2007, 00:27
