I have had no luck with this , I have a backup of a 1080 blu ray movie and I am trying to encode it to a portable HD so I can plug it into my PS3, the picture comes through but the sound is just a hiss.
I am using ripbot 264 and have downloaded all the accompianing programs it requires .
My HD is formatted to FAT32 so I can't encode too big of a file but something is not right.
Thank you
What audio setting are you using? AAC 2.0 should work best. And follow a guide like http://adubvideo.net/how-to/encoding-blurays-mp4-ripbot
That guide didn't work , when i click on add it decodes the entire blue ray then when i click on the "....." next to video in step 3 it opens up the acual blu ray and decodes it - there is no option to get to the Stream files in step 4
Thank you
Authored blu-ray will not play in PS3
By pietermc in forum Authoring (Blu-ray)Replies: 3Last Post: 6th May 2011, 17:34 -
Blu-Ray to Mp4 x.264 1080p won't play on PS3
By Patrick_H in forum Media Center PC / MediaCentersReplies: 3Last Post: 31st Dec 2010, 11:53 -
Can a PS3 play Blu-Ray region free dvd?
By Minx4MadMen in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Nov 2010, 19:15 -
Blu-ray backup won't play in PS3
By DGenerateKane in forum Blu-ray RippingReplies: 40Last Post: 27th May 2010, 01:57 -
mkv, x264, and h.264 to blu-ray to play on PS3
By cyberpimp16 in forum Authoring (Blu-ray)Replies: 1Last Post: 14th May 2009, 15:58
