I have converted an .mkv (avc 1) to divx using xvid4psp and observed that the sound was out of sync (in original mkv the sync is ok). I've checked with MediaInfo the mkv file and saw that the video frame rate is 23.915 (non-standard, I guess...). The frame rate of (bad) converted divx is 29.97, so I believe that the non-standard frame rate of the source file could be the reason for audio desync... Is there a way to manage this in order to get a good (sync) .divx?
Thanks in advance!
Just convert with the same frame rate. Divx doesn't have to be 29.97 fps. But be aware that MKV supports variable frame rates so that may not work either.
Converting MKV to PS3 with a variable frame rate
By hookeyed in forum Video ConversionReplies: 4Last Post: 20th Jun 2010, 07:38 -
AVC in mkv plays with half the frame rate
By nikemouse in forum Video ConversionReplies: 2Last Post: 18th May 2010, 11:42 -
mkv to dvd (frame rate)
By robinmishra in forum Newbie / General discussionsReplies: 5Last Post: 10th Apr 2010, 02:50 -
By robinmishra in forum Latest Video NewsReplies: 1Last Post: 9th Apr 2010, 08:27 -
Frame rate of MKV from DVD
By maass in forum DVD RippingReplies: 2Last Post: 4th Feb 2009, 06:40
