I am not a fan of using those on line instructions.
Is there a PDF for ffmpegX and what is the url to download that file ?
Not that I could find.
Are you aware you can open a tutorial in your internet browser and use 'File>Save as' and save the tutorial in .mht format to your hard drive, then open it off line with your browser? Not .pdf, but you would have the files locally. You can also use the browser controls to zoom and if you want to click the embedded links, they will take you back to the live page. I do it with a PC all the time. Should work with Macs or Linux boxes also. From the ffmpegX site, their tutorials: http://www.ffmpegx.com/howtos.html
Almost every Mac application with a 'Print' function can save the page(s) to be printed as PDF (thanks to Apple's CoreGraphics PDF API).
You could merge multiple PDFs with e.g. Combine PDFs or PDF+PDF or Acrobat Pro, into one tutorial PDF.
Best PDF Editor..
By Soccerman77 in forum ComputerReplies: 1Last Post: 4th Nov 2010, 19:50 -
eBooks to .pdf?
By rotuts in forum MacReplies: 8Last Post: 23rd Oct 2010, 02:59 -
PDF file help
By jyeh74 in forum ComputerReplies: 14Last Post: 10th Jun 2009, 23:45 -
DVDs made with ffmepgx
By dlg1989 in forum ffmpegX general discussionReplies: 1Last Post: 11th Feb 2009, 14:05 -
jpeg to PDF is OK! But PDF to jpeg?
By bryankendall in forum ComputerReplies: 2Last Post: 14th Sep 2008, 15:53
