Hi,
I have used mpg movie and converted it to mpeg TS. using free Ojosoft total video converter.
Than i have played it via winsend and receive dit via StopBox aminet to LCD TV.
The quality is bad , the movie and the sound jumps and does not run smoothly.
I also changed the conversion parameters in order to fit of an HD file that runs smoothly,however not optimal also.
Pls advise what are the best parameters for conversion or should i use other sw conversion ?
BR,
Yoram
	Hi ,
 I have attached the input file and out file as analyzed by media info
 yoram
	First thing to note is that neither file contains mpeg video. Your source is standard definition interlaced PAL DV, and your output is 1080p (progressive) PAL AVC.
 So during your conversion you have deinterlaced the footage, and upscaled it to HD. My guess is that Total Video Convertor does both of these int he quickest, nastiest way possible, so you will never get a good quality conversion.
 If you must output HD, try XmediaRecode. It takes a little longer to set up the encode while you get the padding and framing right (all of two minutes of trial and error in my case - start at around 280 on the left and right), and you might want to do some test encodes with different deinterlace settings (hint - you can set start and end points in the Preview screen for your short tests), but the results are certainly watchable. No jerkiness or jumping on playback.
 If you don't have to output HD, then consider encoding at SD resolutions with high bitrates, and letting your playback hardware do all the upscaling for you.Read my blog here.
	hi ,
 Thanks i used xmedia and i could convert th HD movie ans see it .
 However could not convert it to the same resolution 1920*1080
 what ca i do ?
 BR,
 Yoram
	Since it's not Hi-Def to begin with, what's the point of upscaling it? Why not make an interlaced DVD like normal people, or some sort of a 720x480 MP4 or something like that?
	hi ,
 i am sorry , i ment that i took a nother source file , this time HD with 1920*1080 and could not convert with same resolution
 br,
 yoram
  Playing MPG on Mac - converstion to AppleTVBy brstephe in forum Video ConversionReplies: 2Last Post: 5th Jan 2012, 22:01
  Gotsent converstion problemBy Bigm1ke in forum Video ConversionReplies: 1Last Post: 6th Jul 2010, 22:08
  mpg with a good MP3 sound in music videosBy copiche in forum AudioReplies: 5Last Post: 24th Aug 2007, 13:22
  editer shows 'no sound', mpg plays with soundBy oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 09:01
  DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
