Recently I bought a Samsung MM-DG25 in Europe (Spain). At the present I am using this Samsung MM-DG25 in a different country (Mexico). I am trying to see videos with the Samsung MM-DG25 connected to a TV with NTSC standard and I always see the videos without color (black and white). In this sense, I would like to know, please, if it would be possible to change the TV standard format (video output signal) in the Samsung MM-DG25. I tried to do this using the SETUP option, but the SETUP option does not include the change of TV standard for the video output signal. Regarding the video output of the SETUP, it is only possible to change between P-Scan and I-Scan. I would highly appreciate some recommendation from you regarding the solution of this problem.
Thanks in advance for your comments.
If there is nothing like "PAL - NTSC" in the menu or setup....buy a new player.
Captured video is in black and white (NTSC vs PAL problem?)
By Helena in forum Capturing and VCRReplies: 27Last Post: 18th Apr 2023, 19:34 -
only black & white from S-Video
By Victor Hen in forum Newbie / General discussionsReplies: 11Last Post: 23rd Jul 2012, 21:40 -
How to Upgrade firmware of Samsung MM-DG25?
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 6Last Post: 2nd Feb 2011, 15:25 -
Problem with S-Video: only getting black/white, Composite works fine!
By x92 in forum Capturing and VCRReplies: 20Last Post: 22nd Jun 2008, 10:05 -
HELP, every video on my PC is Black and white ?
By shammi in forum Newbie / General discussionsReplies: 5Last Post: 19th Jul 2007, 08:52
