Hi, I've got a FAT+ and I am using it to play .mkv files. Up to now I had no problem, but when I tried to mux an h264 video track with an aac audio track into a single .mkv, I got a file that works well on my PC (with VLC) but gives a black screen on my FAT+. For the muxing operation I used mkvmerge with default options. Have you any suggestion on what options should I use in mkvmerge to get a file playable on FAT+?
Disable header compression in mkvmergegui, under file->options->disable header removal compression by default.
I wonder if my problem is related - MP4 files with AVC/AAC play fine if I select them from the FAT+ menu, but when playing a whole folder, the audio fails to play quite frequently when going to the next file.
Merged MKV does not play in media player
By sam9s in forum EditingReplies: 6Last Post: 7th Nov 2010, 10:49 -
mkv to avi troubles.
By joonshik in forum ffmpegX general discussionReplies: 3Last Post: 10th Mar 2010, 18:32 -
MKV conversion troubles
By Alexstarfire in forum Video ConversionReplies: 3Last Post: 7th Mar 2010, 15:10 -
troubles with MKV/OGM to MP4
By ironmaidens in forum Video ConversionReplies: 6Last Post: 23rd Aug 2008, 14:18 -
How to remove merged Audio Files from AVi's
By rads666 in forum Newbie / General discussionsReplies: 3Last Post: 16th Apr 2008, 16:42
