Don't worry buddy, you'll learn at your expense
Results 31 to 34 of 34
VCRs sold in PAL countries output PAL60 when playing back an NTSC tape. PAL60 uses 525 lines at 60 Hz – the only difference to "real" NTSC is the color modulation which is PAL.
So all you need to do is tell your capture device the incoming signal is PAL60. This is usually a problem because only few capture devices know what PAL60 is...
Colour correction of a NTSC VHS captured via PAL Equipment
By alesco in forum RestorationReplies: 24Last Post: 22nd Jan 2012, 15:46 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
Convert PAL to NTSC VHS?
By manhnt in forum Newbie / General discussionsReplies: 4Last Post: 29th Jul 2009, 15:49 -
VCR is NTSC, but VHS is PAL
By joelson in forum MediaReplies: 1Last Post: 2nd Jun 2009, 09:21 -
Newbie needs to convert NTSC VHS tapes to PAL DVD
By mcullen8320 in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2008, 14:51
