I've done video editing with Sony Vegas but I am now venturing in to a bit more complicated territory. I need someone to point me in the right direction.
I have hundreds of good quality wmv files that I'd like to convert to flv while doing the following:
1. batch processing
2. add watermark (preferably an image)
3. extract images from the video (say 5 at 20% intervals of video length)
I'm looking for something relatively user friendly and doesn't necessarily need to be free (but I won't argue).
Thanks in advance,
Drew
Results 1 to 11 of 11
ffmpeg can do all that, is free, but not user friendly (requires scripting, writing code)
something like sorenson squeeze is probably what you're looking for , but I don't think it can do #3 , but there are many free tools that can do #3 -
I'm OK with the extra step of converting to flv with something else (macromedia). I can do that in batches as well.
The one thing I'm looking for is a script to extract thumbnails (5 evenly distributed from each region) from the video for each region. Does anyone know if there is an existing script floating out there somewhere? -
There are a few that can do 4 or 6 frames evenly spaced, but 5 I dunno.
(That's a joke)
Are you trying to do those videos where it's a sequence of stills? I'm working on one of those too, except I'm using actual stills from five frame bursts.Last edited by budwzr; 19th Jan 2011 at 12:40.
I want to get the 5 (or whatever number) images for a preview on my site so that when a user hovers over with the mouse it runs a preview. This is a typical feature you see on tube sites.
What are some of the scripts/programs that do this? -
check here:
https://www.videohelp.com/tools/sections/desktop-screen-capture
something like scenegrabber or imagegrabber, I think some some of them have CLI interfaces suitable for batching
ffmpeg can do it too, but I'm not sure of the exact syntax for what you want to do -
I found that video thumbnail maker does pretty much what I'm looking for. I wanted the images to be separate files as opposed to one image with the multiple images on it.
Starting a new project
By jmofosho in forum RestorationReplies: 2Last Post: 15th Dec 2009, 14:48 -
Starting out, maybe venting or both
By Oldone in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2008, 18:38 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 17:47 -
starting over-codecs
By uglijimus in forum Video ConversionReplies: 5Last Post: 14th Jul 2007, 08:57 -
Problem Starting up Beta 2.5
By mwkurt in forum SVCD2DVD & VOB2MPGReplies: 27Last Post: 14th Jun 2007, 03:42
