Going to go from an .mpg to DV avi, using Virtualdub. I also anticipate using the Thalen Deshaker in Virtualdub and it seems the best results are gotten with deinterlaced video.
Any problems with deinterlacing going from mpg to .avi? Should I go to avi first and then deinterlace? Will it make any difference? Using the MainConcept DV codec.
Any advantage going to uncompressed as an intermediate step?
Thanks.
You should use AviSynth to bob deinterlace with QTGMC(). Then deshake in VirtualDub. Finally reinterlace with VirtualDub for DV. Or you could do all the filtering in AviSynth:
Mpeg2Source("filename.d2v")
QTGMC()
mdata = DePanEstimate()
DePanStabilize(data=mdata)
SeparateFields()
SelectEvery(4,0,3)
Weave()
ConvertToYUY2(interlaced=true) -
DV AVI is interlaced, so de-interlacing is probably going to make things worse. If you go to Lagarith or Huffyuv in an AVI container you might get better results.
What will your final format be ? If it is not DV then I wouldn't go there at all. Use a lossless codec (again, lagarith or huffyuv) as your intermediate. Open the mpg in virtualdub directly, or through an avisynth script that does your deinterlacing for you. Reducing re-encoding to an absolute minimum.Read my blog here.
Trimming AVI in virtualdub,direct strem copy ignores my start and end point
By Rudyard in forum EditingReplies: 4Last Post: 4th Oct 2010, 20:11 -
From Point & Shoot Digital Camera AVI to Xvid High Quality
By kamil in forum Video ConversionReplies: 5Last Post: 25th Jul 2009, 10:28 -
Power Point to AVI?
By stantheman1976 in forum Video ConversionReplies: 5Last Post: 6th Mar 2009, 12:45 -
AVI.NET---- What is and do I need to decomb/deinterlace?
By siratfus in forum Video ConversionReplies: 4Last Post: 4th Aug 2008, 01:09 -
Best point at which to Convert?? (NTSC AVI to PAL DVD)
By junk in forum Video ConversionReplies: 3Last Post: 28th Jun 2007, 17:15
