hi i am new to this field, so i really need help, i have a 4hr mpeg 2 video and i need to fit it into a 4gb dvd-r disk without as much as reducing its quality. i wld like to knw first of all if its possible to put a 4 hr video into a 4gb disk and still have superb quality, then i wld like to knw how i can achieve this even though it may not give me the quality that i desire.
thank you so much
Not likely unless they're already sized to both fit on a 4.37GB DVD-5 disc. If not, you would need to re-encode and that will lower the quality. How much depends on how much more they need to be compressed to fit. Optionally, you could put the videos on a 7.95GB DVD-9 disc. (A dual layer disc)
You would also need to author the MPEGs to the DVD standard if you want to play back on a set top DVD player.
I also changed your title to fit with our rules.
And welcome to our forums.
As redwudz suggested, since it is already compressed for MPEG-2, re-compressing will lower the quality further.
If it was an AVI file, I would have used Half-D1 resolution in FAVC.
Since it is an MPEG-2 file, I am not sure exactly which is the best tool to compress it further. But it is possible, there will definitely be loss of quality. -
Honestly ? I would put HCEnc up against either of those encoders. It is faster than Procoder and produces better results, it is slower than CCE, but produces much better results at lower bitrates. And 4 hours on a single layer disc means a low bitrate. Rebuilder also requires an authored DVD as input, which the OP currently does not have.
@missyfy - it would help if you posted a mediainfo of the source file so we can see what you have. It may need a little work, or it may need a lot.If the source file is already small enough to fit on a single layer disc, go for it. At least you can't make it worse. If it is larger than a single layer DVD (4.38GB - and don't forget there are authoring overheads to accommodate as well), then you will only reduce the quality trying to squeeze it down. If quality is important then you really only have two options - dual layer or two discs.Read my blog here.
4hr 38min DVD9 - Is this ok?
By sdsumike619 in forum Authoring (DVD)Replies: 5Last Post: 16th Jan 2012, 20:28 -
How can I take 6GB content to fit into 4GB DVD?
By Han Solo1 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Mar 2010, 14:20 -
Video won't fit on dvd
By chevyfever in forum Video ConversionReplies: 5Last Post: 6th Nov 2009, 08:50 -
Can I fit 5.3 GB video on a 4.7 GB DVD?
By better life in forum Authoring (DVD)Replies: 13Last Post: 16th Nov 2008, 21:42 -
Mpeg files wont fit onto one DVD
By jayman34 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 03:43
