Hello everybody,
I've installed K-Lite_Codec_Pack_670_Mega and I have installed the plugin to read .MP4 in virtual from this page : https://www.videohelp.com/tools/virtualdub. I put it in the Plugin folder of VirtualDub.
The problem is that it doesn't work. Thanks to the plugin I can open the video but the screen is black and when I push play the screen stay black even if it seems that the video is read. I tried it with Windows Vista 32bit and also with Windows 7 64bit and the problem is the same on both.
I've then installed the AMVapp pack (http://www.animemusicvideos.org/guides/avtech/amvapp.html). I tried also to create an .asv file with DirectShowSource("C:\mypath\myfile.mp4") in it, this open the video but the screen is green and when I push play VirtualDub crashes.
I have no idea how I can solve this problem, I would be very thanksfull if one of you could help me and explain me hox to do because I'm beginner in video processing or codec managment.
Thanks you in advance
Results 1 to 9 of 9
Moving you to our editing section. Did you try the directshow plugin http://forums.virtualdub.org/index.php?act=ST&f=7&t=15093&st=0 ?
Thank you for the reply.
I tried it but it still doesn't work.
The video I have to read is coming from a camcorder SANYO Xacti HD2000 and it has been recorded in FULLHR.
Here are some information that i obtained with the MediaInfo tool of the K-lite codec pack :
General
Complete name : MP4video.MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 36.3 MiB
Duration : 12s 846ms
Overall bit rate : 23.7 Mbps
Movie name/More : SANYO DIGITAL CAMERA HD2000
Encoded date : UTC 2011-01-13 00:14:08
Tagged date : UTC 2011-01-13 00:14:08
Origin : Digital Camera
TAGS : O DIGITAL CAMERA
Video
Format : AVC
Format profile : High@L4.2
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : avc1
Bit rate mode : Variable
Bit rate : 23.4 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.188
Stream size : 35.8 MiB (99%)
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 12s 842ms
Bit rate : 128 Kbps
Maximum bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 200 KiB (1%)
Language : English
Tagged date : UTC 2011-01-13 00:14:08 -
1) install avisynth
2) download ffmpegsource2 plugin, unzip to avisynth/plugins directory (especially the .dll and .exe)
http://code.google.com/p/ffmpegsource/
3) create a script: open a .txt file in notepad in the same directory as video, change the filenames/paths to match, save it, change extension from .txt to .avs
aud=ffaudiosource("video.mp4")
vid=ffvideosource("video.mp4")
audiodub(vid,aud)
4) open .avs in vdub -
Thank you for your advices.
After installing the last version of Avisynth I tried the script :
aud=ffaudiosource("Z.mp4")
vid=ffvideosource("Z.mp4")
audiodub(vid,aud)
but it doesn't work and gives me this error :
Avisynth open failure:
FFIndex: Failed to open 'c:\Z.mp4.ffindex' for writing
(C:\Z.avs, line 1)
Do you know what can be the problem ?
Then, I tried again the script :
Directshowsource("C:\Z.MP4")
This didn't work before I tried what you advised me but now it's working ! The picture stops sometimes but at least I could open it. It seems that it's the installation of the last version of Avisynth which made it working.
Anyway if you have an idea of what could be the problem with the other script [aud=ffaudiosource("Z.mp4")/vid=ffvideosource("Z.mp4")/audiodub(vid,aud)] and what does the error message means i'm interested in it because I would like to understand this problem. -
Looks like it is failing to create the index file.
Do you have write access to "C:\"?
Which version of ffms2 are you using?
It's odd that the error message mentions FFIndex (rather than FFAudioSource or FFVideoSource), since you don't call that in your script. -
The MP4 plugin in that link is broken and the author dropped support long ago. You need to use the quicktime input plugin instead.
Maybe try VFW configuration in ffdshow and enable support for MP41, MP42, MP43 and maybe Other MPEG4 (MP4S, M4S2)
...Or try with old MS MPEG-4 VKI codecs. -
Hello, sorry that I couldn't answer before. Thank you very much for your replies, it's working, I can play MP4 format. It is still quite unstable but it's working.
Thanks.
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 10:30 -
ATI TV Wonder 650 PCI - Black Screen in virtualdub
By HidenSeek in forum Capturing and VCRReplies: 50Last Post: 21st Mar 2012, 10:18 -
VirtualDub shows H.264 as black screen
By banksters in forum Video ConversionReplies: 19Last Post: 24th May 2011, 08:36 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
