I want to know some basics about conversion.
1. Does only bit-rate matter to output file size or resolution too?
2. For 640*360 what is optimal bit-rate? I am currently using 2mb for mpeg4 (h263), is it enough, less or overkill?
Thanks.
1. Only bitrate.
2. Overkill. Around 1Mbit would be enough. -
thanks.
what i understand that if I need higher resolution then I have to increase the bitrate and for lower resolutions low bit rates are good.
is there any res to bitare chart? -
Bits per pixel
http://www.silverjuke.net/forum/topic-213.html
Its saying
0.20 - 0.25: It will look really good.
0.25 - 0.30: It won't really improve visually.
so i think 1.5mb is enough for my resolution in most cases.
but again 1.5mb would be enough for movies like avatar, transformers etc?
Conversion help.
By yugub in forum Video ConversionReplies: 9Last Post: 18th May 2011, 20:45 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
2.35:1 conversion to 1.85:1 (or 1.77:1)
By mgarrido in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2007, 23:21 -
Conversion
By firoril in forum Video ConversionReplies: 1Last Post: 2nd Aug 2007, 10:46
