Hi,
I am creating a DVD with 'AVSTODVD' very nicely & authoring with GFD finally & burning with Nero 7.
But, I can't make the menu/title with Animation. I mean now just using still images & using text/buttons( Play/Chapters etc) on the image of that movie.
The animation option is disabled in the GFD. So, GFD not support animation title or which free version of GFD support animation. I want to use GFD, because I think it's very easy to author DVD with thgis soft.
Thanks...
~r
Yes, but this is just the default. If you activate 'Animated menus' in the default settings, (it is recommended that you do this before you add any movies, menus, buttons...), then you can create animated menus in GfD.The animation option is disabled in the GFDGUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Hi Borax,
Many thankx. Actually same thread I discussed long time ago.
I also found how to activate animation in GFD.
But, is it possible to make animated title in GFD or I've to make using other soft in specific format, then include in GFD?
If yes, then do u know any referance, u r familiar with? Is there any web site from where I can download animated titles.
Plzzzz...
Thankxxx -
It depends what you exactly mean by 'animated titles'. GfD can automatically create buttons where a short (depending on the length of the animated menu) part of the added videos is shown. You may also add any DVD compliant video (elementary stream!) as menu background. You may even use animated Gif files which may be shown with transparency on the menu background after conversion into 32 bit AVI files (ARGB format). Just have a look in the guides:
http://download.videohelp.com/gfd/Help/ShortdescAnimMenus.html
http://download.videohelp.com/gfd/Help/TransparencyEffectsAnim.html
http://download.videohelp.com/GFD/Motionmenu_eng.htmlGUI for dvdauthor:
GfD Muxman Error
By michcio in forum Authoring (DVD)Replies: 2Last Post: 14th Jan 2009, 13:11 -
SUP format in SubtitleCreator (to use in GfD)
By michcio in forum SubtitleReplies: 70Last Post: 15th Aug 2008, 09:43 -
GFD - transitions between menus
By dani96 in forum Authoring (DVD)Replies: 0Last Post: 24th Jul 2008, 07:23 -
GfD timecode error
By bratpop in forum Authoring (DVD)Replies: 3Last Post: 5th Jan 2008, 10:53 -
GfD: how do I jump to chapter 1?
By AlanHK in forum Authoring (DVD)Replies: 2Last Post: 9th Aug 2007, 06:10
