I have a bunch of DVD's (owned by me with my footage), that I would like to bring into Adobe Premiere and make movies. I downloaded DVD Shrink to rip the DVD to my hard drive, but I would prefer to have multiple clips divided by when the camera record button was pressed, instead of one huge long movie clip that I have to shorten hundreds of times during the edit process. Thanks!
I don't see any option like this in DVD Shrink... other than "Split VOB files into 1GB chunks", but that's not what I'm talking about. Also, these files are in VOB format, so I guess I would need some free converter before using MPEG2Cut2?
I don't use Premiere so I have no idea whether or not it handles VOBs. VOBs can be converted to MPG using VOB2MPG.
No, it handles VOBs easily and well.so I guess I would need some free converter before using MPEG2Cut2?
After the DVD is on the hard drive Shrink can be used to cut the big VObs into smaller VOBs, but I'd use MPEG2Cut2. Actually I use the older MPEG2Cut found at the same link. -
DVD to editable file
By quitosky in forum Newbie / General discussionsReplies: 1Last Post: 8th Sep 2009, 13:49 -
Authoring an auto play DVD or editing an exsisting ONE to auto play
By theewizard in forum Authoring (DVD)Replies: 22Last Post: 16th Mar 2008, 12:06 -
About editable dvds being able to play on most dvd players?
By akanashi_jin in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 11:21 -
HELP... Ripping video from dvd but still editable?
By nigus4life in forum EditingReplies: 2Last Post: 1st Jul 2007, 13:48 -
DVD to something editable
By investingstuff1971 in forum DVD RippingReplies: 2Last Post: 10th Jun 2007, 11:58
