Hey.
I have all my movies on my harddrive as .iso files, inside the .iso files there is the normal video_ts folder.
All the movies have normal subtitles where you can select languages.
I want to hardcode the subtitles into the movie, but how can I do that the easy way?
I want the output to bee either a .iso file or a video_ts folder.
Can this be done? or is it nessesary to encode all the movies into .avi and back to dvd again?
I realy hope you guys can help me.
Best regards.
The reason I need the movies in video_ts / .iso, is that I can burn a fast copy if I want to.
If I convert then all to avi, I will loose quality (I think), and I will have to convert them to a dvd format if I want to burn it on a disk. -
You will lose quality whatever method you use as hardcoding requires reconverting.
As an alternative to hard coding them you could modify the commands on the DVD to default the subtitles ON - see this guide
http://download.videohelp.com/r0lZ/pgcedit/third_party/2cool/subtitles/subtitles_on_de...lt_pgcedit.htmSONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
A/V out of sync after conversion with hardcode subs
By kidlat020 in forum Video ConversionReplies: 3Last Post: 15th Mar 2011, 22:57 -
Hardcode subs on .m2ts???
By LoveMyslf in forum Video ConversionReplies: 6Last Post: 15th Sep 2010, 17:28 -
Hardcode Subs
By Gh0st Rav3r in forum SubtitleReplies: 1Last Post: 16th Oct 2009, 17:47 -
How to hardcode subs in .MKV
By CERO in forum Newbie / General discussionsReplies: 5Last Post: 2nd Aug 2009, 11:21 -
hardcode / burn the subs on the video
By greendesert in forum Video ConversionReplies: 1Last Post: 20th Jul 2009, 12:55
