Hi guys, I have been using decrypter to Shrink which then automatically provides dialog boxes to burn my encoded video files using Nero 7. I am now using imgburn instead of Nero . I am unfamilair with imgburn, what happens when I get to the BACKUP stage in DVD Shrink. Cheers
visionman
Health IS the first Wealth------So do not strain your eyes!
Save the output as VIDEO_TS folder, then open ImgBurn and drop in the VIDEO_TS folder and burn.
Or you can get the modded Dvdshrink .exe and set it up to automatically burn with ImgBurn the same as shrink will do with dvddecrypter or the older versions of nero.
The search function is our friend
https://forum.videohelp.com/threads/314270-Instructions-for-DVDShrink-with-ImgBurn?p=20...=1#post2016825
https://forum.videohelp.com/threads/329448-DVD-Shrink-won-t-recognize-Nero%28New-PC-wit...nero+dvdshrink
https://forum.videohelp.com/threads/330025-Trying-to-burn-a-dvd-using-dvd-shrink-and-Ne...nero+dvdshrink -
Thanks Noahtuck, indeed the search function is our friend however on this occasion I was misled all over the place . Thanks again for your links
visionmanHealth IS the first Wealth------So do not strain your eyes! -
Additional message.regarding links from Noahtuck
Hi Noahtuck, just read through the link posts concerning “thread : Instruction for DVD Shrink with Imgburn” I put the posts on a Pen drive, too many to read at the time of viewing.( Public access machine) Thank you for your clear , simple instructions on my original post ,and screenshot explanation on the thread. (An excellent resource for people unfamiliar with the settings.) Also good helpful advice regarding having the burning software (Imgburn) installed before DVD Shrink.
Cheers visionmanHealth IS the first Wealth------So do not strain your eyes!
I/O errors using ImgBurn and DVD Decrypter
By jcsdmd in forum Newbie / General discussionsReplies: 16Last Post: 27th Aug 2011, 14:58 -
How do I get ImgBurn to work with Shrink?
By Jonathan in forum DVD RippingReplies: 8Last Post: 27th Dec 2010, 15:09 -
Need help with shrink 3.2 and imgburn
By Seekyr in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2010, 00:37 -
Dvd Shrink + Imgburn
By angryassdrummer in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2007, 23:54 -
Burn audio CD with ImgBurn and DVD Decrypter - not enough space
By theWallflower in forum AudioReplies: 11Last Post: 7th Aug 2007, 15:21
