Results 1 to 1 of 1
  1. hi . when i Ripping the Video This problem Show up to me always
    The problem with the movies Bute with the anime it's fine !
    i know; my English is Bad
    Video Information
    General
    Complete name : D:\none\45489\m-piranha-1080p.avi
    Format : AVI
    Format profile : OpenDML
    File size : 2.56 GiB
    Duration : 1mn 47s
    Overall bit rate : 204 Mbps
    Writing library : VirtualDub build 30586/release
    Video
    Format : Huffman
    Codec ID : HFYU
    Duration : 1mn 47s
    Bit rate : 202 Mbps
    Width : 1 920 pixels
    Height : 800 pixels
    Display aspect ratio : 2.40:1
    Frame rate : 23.976 fps
    Color space : RGB
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 5.490
    Stream size : 2.54 GiB (99%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Codec ID/Hint : Microsoft
    Duration : 1mn 47s
    Bit rate mode : Constant
    Bit rate : 1 411.2 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Bit depth : 16 bits
    Stream size : 18.2 MiB (1%)
    Interleave, duration : 42 ms (1.00 video frame)
    Interleave, preload duration : 500 ms
