Have a DVD created, wanted to see if I could modify the audio of the menu directly without changing anything else. The menu has text over a video.
Located the VOB file that has the video for the menu. Changed the extension to .mpg, loaded it into Pinnacle Studio, replaced the audio, recreated a new mpeg-2 file, gave it the same name as the original and put it in the Video_TS folder.
However on playback while the menu looks more or less the same, the playback is hitchy, there's NO audio and no menu item selectability.
So obviously there's more going on here. Why didn't this work and is there a way to do what I tried to do?
Thanks for all input.
Results 1 to 9 of 9
Your method wont work.
Try author your mpg to a vob with muxman and then use vobblanker to replace the menu vob. See for example https://www.videohelp.com/guides/how-to-replace-dvd-menus-with-vobblanker-avi-video-id959#959 -
Your method won't work....plain and simple. You can sometimes rename a VOB into an MPEG files....but that's where it ends. You cannot edit one VOB of the DVD then stick it back in.
"The VOBs have been authored to be part of the specified DVD structure that "lives" inside of the VIDEO_TS folder and only inside the VIDEO_TS folder" is the best way to explain it. All of the VOBs inside that VIDEO_TS folder rely on each other.
Not sure if you can edit your menu again but I'm pretty sure that you can edit the videos.
menu button didn't work
By pcb in forum Authoring (DVD)Replies: 6Last Post: 13th Oct 2010, 16:07 -
how to modify mpeg2(*.vob)'s Writing library
By 10362227 in forum ProgrammingReplies: 1Last Post: 12th Jul 2010, 21:15 -
Extract Subtitle embled in AVI file,VirtualDubMod n GraphEdit didn't work..
By quang010692 in forum SubtitleReplies: 1Last Post: 5th Oct 2008, 03:44 -
My new Harddrive didnīt work, to weak computer?
By Espen in forum ComputerReplies: 6Last Post: 24th Sep 2008, 14:47 -
no sound when i captured from dv in adobe prem cs. even hd didn't work
By cannibalcam in forum AudioReplies: 7Last Post: 5th Mar 2008, 08:07
