Newbie here. I don't even know the correct terminology. I have a Sony DSC-HX5V point & shoot camera. It says it takes video in the AVCHD format. But when the file shows on my computer (PC with Vista), the extension is m2ts. What is the correct term to use for this format?
The software that came with this camera is called PMB. Using this software, I'm able to trim the video to create shorter clips. But it does not have the functionality to put the clips together. I'm looking for software (free) that will put the clips together. That's all I need. I know there are a lot of programs out there, but I can't find any that mention this particular format. Any & all suggestions would be greatly appreciated. Thank you so much.
http://www.kiva.org/about -
Try the free tsMuxeR.
In the Input window:
Click [add button] to add your first m2ts clip [if the program does not accept m2ts files rename them to clip1.ts , clip2.ts .. etc]
Click on [join button] to join the other clips
Set the [output] to AVCHD disk
Click on [start muxing button]
The program will make an AVCHD disk structure called BDMV. Open it and look for the STREAM folder. Open this folder and you will see a 00000.m2ts file which has all of your clips.
Welcome to this forum!
Convert AVCHD Video (.m2ts).
By Oilte in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 07:56 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 01:06 -
Why do I need to convert AVCHD (.m2ts) files ??
By lombiz in forum EditingReplies: 7Last Post: 27th Feb 2010, 21:54 -
Converting mkv to m2ts or AVCHD
By carlosian in forum Newbie / General discussionsReplies: 13Last Post: 20th Sep 2009, 17:42 -
Editing AVCHD (.m2ts)
By 4real1970 in forum Newbie / General discussionsReplies: 1Last Post: 25th Sep 2007, 13:50
