    Jan 2011
    New Zealand
    Hi all,
    first post on this forum, hopefully someone can help.
    I am having problems installing the ffxmgx program on my mac.
    All o.k until I try installing the part that requires using the terminal.
    I follow all the instructions on this page http://ffmpegx.com/download.html#metadata
    but when i type ruby setup.rb config
    i get this message ruby: No such file or directory -- setup.rb (LoadError)
    Any help will be appreciated much.
    Thanks.
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Videohelp.com has an ffmpegX forum. Perhaps a moderator can move this topic there?
    Regarding your issue:
    1/ Make sure you use the main shell window in the Terminal (not the New Command/Run Command).
    2/ Beware of spaces: each command line word should be separated by a space character. E.g. right after 'cd'.
    cd <space> <drag-and-drop folder 'flvtool2-1.0.6' here> <return>
