Hi. I'm converting some wmv files (25fps) to mp4. Is there any benefit to making the mp4's at 29.97fps or is it better to leave the fps as 'original'?
Thanks for any suggestions.
As you are in the UK and the original file is 25fps (UK standard) why would you want to convert to 29.97 (USA standard) ?
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Thanks for that. I know the UK standard is 25 but my DVD player handles 25 and 29 (I'm going to be watching these files via my DVD player and TV) . My logic (warped or otherwise) tells me that 29fps would generate a smoother picture than 25.
You only have 25 fps to play with. To create 29.970 fps you would have to either duplicate almost 1 frame in every 5, or blend almost 1 frame in every 5 in order to make up the missing frames. Either way you get stutter, not smooth playback. Or you could simply speed everything up to 29.970 fps, and make everything look silly by having it all move 20% faster than normal. Neither gets you what you want.
Read my blog here.
Thanks again. I've obviously got the wrong idea about what a conversion program does - I imagined it as a 'camera' making a fresh recording of the original video meaning you could set it to whatever fps you liked.
For that you need to go back to the camera and shoot again
It is possible to interpolate to a different frame rate but that adds blur and artifacts.Last edited by edDV; 16th Jan 2011 at 18:06.
http://www.kiva.org/about
24fps or 29.97fps ???
By RodNichols5 in forum Capturing and VCRReplies: 29Last Post: 27th May 2011, 18:26 -
29.97fps subs to a 25fps Video?
By solrage in forum Authoring (DVD)Replies: 34Last Post: 1st Feb 2011, 22:16 -
Help with HD @ 29.97fps to DVD at 25fps
By Killer3737 in forum Video ConversionReplies: 9Last Post: 19th Nov 2009, 15:29 -
23.97fps to DVD
By El Duderino in forum Authoring (DVD)Replies: 2Last Post: 29th Jan 2009, 08:27 -
Converting 30fps to 29.97fps ?
By blewyn in forum Video ConversionReplies: 2Last Post: 19th Mar 2008, 11:24
