  1. Hi,
    I have a program that captures videos streams in asf formats. The files play fine without any issue.
    When I try to convert the asf file to any other format, I get audio sync problem.
    I tried many video converters (super, DVDfab, handbreak, MS movie maker) and the result is always the same.
    Is there something I need to do before I convert these files? Below is the media info for the file
    General
    Complete name : C:\an1.asf
    Format : Windows Media
    File size : 35.1 MiB
    Duration : 5mn 34s
    Overall bit rate : 880 Kbps
    Maximum Overall bit rate : 933 Kbps
    Movie name :
    Performer :
    Video
    Format : VC-1
    Codec ID : WMV3
    Codec ID/Info : Windows Media Video 9
    Codec ID/Hint : WMV3
    Duration : 5mn 34s
    Bit rate : 805 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 fps
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.087
    Stream size : 32.1 MiB (91%)
    Audio
    Format : WMA
    Format version : Version 2
    Codec ID : 161
    Codec ID/Info : Windows Media Audio
    Duration : 5mn 34s
    Bit rate : 32.0 Kbps
    Channel(s) : 2 channels
    Sampling rate : 32.0 KHz
    Bit depth : 16 bits
    Stream size : 1.28 MiB (4%)
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    WMV....that explains it all. Just as bad as FLV. Both are virtual dead ends without a lot of work involved.
  3. Thanks guys. I was hoping for a more quick and easy way to do this. We only need to convert these files for nthe kids ipod. Since they can watch these on the computer fine, I think I will experiment and see if there is an easier solution.
    andy99: PLease don't cross post. Bump your thread instead.
    Solution in https://forum.videohelp.com/threads/330752-converting-asf-file-audio-sync-issues?p=2048...40#post2048940
