Not sure if I use the right vocabulary here ( Im just a newbee ) but let me describe my problem :
I used Aon Ultra Dvd Ripper to rip my DVDs to PSP format ( playstation portable ) but the PSP list the filee with the DVDs encoded name . Once ripped to MPEG-4, is there a way to edit the name TAG so that I can choose the title that will be displayed ???
Madonna
	In 'Control Panel>Folder Options>View', do you have 'Hide extensions for know file types' UNCHECKED?. Otherwise, you can't change the extension name, if that's what your problem is. '.exe', '.jpg', '.mpeg', etc, are some names of extensions.
 And welcome to our forums.
	You need an Mp4 editor/remuxer. Like this www.videohelp.com/tools/abcAVI_Tag_Editor
 You're not even a NewBee, Nuby!Corned beef is now made to a higher standard than at any time in history.
 The electronic components of the power part adopted a lot of Rubycons.
	Thanks buddy ! Unfortunately, abc does not support MPEG-4 video files . I've been looking around the net for more than 3 days now and just cant find any support . There is gotta be something outhere ! Maybe, no one can decode these files ???
 Madonna
	You could try XmediaRecode. Keep the container the same, and use Copy mode for both the video and audio. Second to last tab has a lot of tag fields you can fill in before saving a new copy. Should be no quality loss. Read my blog here.
  MKV Tag EditorBy gonwk in forum Newbie / General discussionsReplies: 32Last Post: 24th Jan 2021, 10:39
  Adding 3d tag?By catdaddio6 in forum Newbie / General discussionsReplies: 7Last Post: 10th Aug 2011, 19:47
  removing author tagBy dehshaun in forum EditingReplies: 5Last Post: 23rd Dec 2010, 12:54
  abcAVI Tag Editor: Add, Browse and Change AVI tagsBy devilcoelhodog in forum Newbie / General discussionsReplies: 0Last Post: 1st Mar 2009, 08:37
  Possible ID3 Tag ProblemBy Graham099 in forum Authoring (DVD)Replies: 0Last Post: 11th Jul 2007, 07:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
