Hi There,
I'm currently in the process of converting various pop videos to VCD. Many of these are in Quicktime format. I use TMPGEnc to encode to VCD and so I downloaded the QTReader.vfp. It works really well but now I cannot encode any MPG files. TMPGEnc gives me invlalid floating point errors.
If I remove the QTReader file then it works as normal again. Does anyone know if there is a way to get TMPGEnc to work with the QTReader, so that I don't have to remove it everytime I want to encode MPGs?
You can get the link from this site. Try this URL:
http://www.geocities.com/SiliconValley/4942/svcd.html
Regards,
Asprinwizard -
Yep i tried that QT reader vfp file and tmpgenc didn't work right till I removed the file.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
