i burned a dvd from a dv-avi file, but when i play it back in vlc media player the video is not deinterlaced and i have to turn on deinterlacing in the program.
my dvd player though, plays the video very smoothly when i pop in the same dvd.
my question is: will ALL dvd players play back my home made dvd's (made from mini-dv cassette camcorder) smoothly and deinterlaced?
(i use avstodvd to burn the dvd)
Results 1 to 13 of 13
If the DVD is properly made either the DVD player or TV will deinterlace, depending on the setup.
You said it wasn't being deinterlaced in VLC but when you chose a deinterlacing method it got deinterlaced. So what's the problem? Your standalone DVD player deinterlaces it properly (if going to a progressive display, no deinterlacing needed if going to an interlaced CRT TV set).
Sometimes software DVD players have to have deinterlacing turned on. -
It's possible the video has interlaced frames but is encoded as progressive MPEG 2 -- and the DVD player just happens to be outputting with the correct field order over an analog output so it looks ok on the TV. Another DVD player might decide to use the opposite field order and the video would be jerky on TV. VLC seeing the progessive encoding would then just display as if it was progressive.
Basically, make sure you encode interlaced with the correct field order. Bottom field first for DV AVI. -
You can make a 480i or a 480p DVD disc and it will play properly in all DVD players. Generally it is better to encode MiniDV format to 480i (lower field first).
A non-progressive DVD player will play both type discs as 480i. The 480p disc is telecined to 480i. A CRT TV will play 480i directly. A progressive TV must first inverse telecine or deinterlace to 480p, then upscale to screen resolution.
A progressive DVD player can play out as 480i or 480p depending on output settings. If 480p is selected a 480i disc gets deinterlaced or inverse telecined to 480p in the player.
An upscaling DVD player can do all of the above plus upscale to 720p or 1080i in the player. If you upscale a 480i disc to 1080i, interlace is maintained. A progressive disc is telecined to 1080i.Last edited by edDV; 15th Jan 2011 at 21:53.
http://www.kiva.org/about -
You should also try free MPCHC
Combining Mini-DVDs into 1 DVD
By Jinga in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2010, 12:06 -
are there any blu-ray players that can be made region free for dvd's?
By CODEWERKX in forum Newbie / General discussionsReplies: 2Last Post: 25th Sep 2009, 14:26 -
Do HD-BURN CD made with Nero work in DVD Players...
By Ensign in forum Authoring (DVD)Replies: 5Last Post: 11th Sep 2009, 23:43 -
What is a good price to copy Mini DVDs to DVD-5?
By Des in forum Newbie / General discussionsReplies: 5Last Post: 3rd Dec 2008, 13:54 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 21:59
