Hi,
I would like to be able to listen all zones with my DVD Player, a Sony DVP-NS67P.
I bought a lot of DVD in Europe and I buy here also, in Canada. There where nothing in the thread Hacks DVD for my DVD Player.
Can you help me? How to program my DVD Player Sony DVP-NS67P to get all zones?
Excuse my bad english! Thank's a lot!![]()
Results 1 to 11 of 11
Not all players can be hacked. Sony is one of those that may likely be in that category.
If so, you have two common choices: Run the DVDs through a program that removes region codes and burn a new disc. Most decrypters will remove the region code (Or actually set the region code to zero, or all regions), or you could get a different player that can be easily hacked. Optionally, you could just play them back on a PC that's hooked to your display.
You may also run into a PAL>NTSC display problem if your player and system can't play both formats.
And welcome to our forums.
Redwudz ,
Thanks for your fast reply. So, there is finally nothing to do with the remote to get all zone?
I checked in the lists (DVD Hacks) and there are few Sony that you can do it!
Thank for your help!
I will buy another DVD Player which I can change zone by programming the Remote. Do you have some advice which Co., I can buy in Montreal, Canada? A cheap one? Thanks!
Bonjour Torvisse
Idéalement, tu devrais t'acheter un 2e lecteur qui qui accepte les PAl et NTSC. Va voir ce site canadien:
http://www.multiregiondvdplayers.net/product/VO-360KHD
À + -
16/9,
Merci beaucoup!
Il y en a un pas cher! C'est quand même dommage de ne pouvoir trouver le truc pour modifier les zones du Sony, quand on l'a déjà payé!
hech54,
Thanks for the advice! Anayway, I will not buy anything else than a DVD Player!
By the way, you do not know the way to fix my Sony?
Sony players are NOT high on the list as being the most "hackable". You may have no choice but to buy another player.....or watch your PAL - Zone 2 discs on your computer.
Or, if you have a computer you can connect to you TV, just rip the disks to the hard-drive and play them that way.
Thanks all of you! I have a lot of "zone 2" and I cannot burn all of those before watching!So, I will buy a real DVD player "all zones". Why can we listen all CD's but not read all DVD's? The awnser is $$$$
sony dvd player dvp-ns67p without picture
By kamran-ns67p in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Aug 2010, 14:44 -
Cannot play Zone 1 disc on my Sony dvp-sr100 DVD player
By lea in forum DVD & Blu-ray PlayersReplies: 12Last Post: 23rd Apr 2010, 14:24 -
Multi zone for Sony DVP-FX930
By Alexander, Ufa in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Aug 2009, 14:52 -
Sony dvp-fx811 portable dvd player region change
By jcgazque in forum Portable VideoReplies: 0Last Post: 2nd Jul 2008, 15:35 -
Sony DVP-FX810 Hack (Multi-Zone)???
By mediawave in forum DVD & Blu-ray PlayersReplies: 7Last Post: 19th Nov 2007, 11:07
