Hi,
A few years ago i made a holiday dvd from a Hi8 tape. Now years later i found out about NeatVideo plugin and about color correction. I would like to redo the main movie and clean it up. Unfortunately i don't have the project files anymore that i used to author the dvd. I still have my original footage, but i don't want to redo the dvd structure.
Is it possible to decompose the dvd and replace only the main movie in the dvd? I want to keep the structure and menus. In the movie nothing will be changed except quality (noise removal and color correction).
I hope someone can give me advice.
Thanks.
Edit Homemade DVD [GUIDE] - decompile disc
Restore, Filter, Improve Quality [DISCUSSION] - lots of advice for restoring video here, too.
Make a new menu. Generally very difficult or simply impossible to majorly redo menu without source files.Want my help? Ask here! (not via PM!)
Yes, use this guide:
http://jsoto.posunplugged.com/guides/VobBlanker/adding_menus/index.htm
This guide is meant to re-insert a DVDShrink re-authored (main movie) DVD back into the original structure (with menus). The principle is the same though. The parts relevant to you start at Step 6. Once you have processed a titleset, you need to author it (with ReJig, for example) to be able to import the VTS_01_0.IFO into VobBlanker.
That should work. It's been quite a while though since I've done it (having moved on to AVCHD/BD). So someone correct me if I'm wrong or missed something.
And welcome to the forum. Good luck.Pull! Bang! Darn! -
Thank you all for the fast answers. How could i forget VOBBlanker?
. I will give that a try.
I wonder if the chapter points will still work? It should be i think since the movie length is unchanged.
In worse case i will reauthor my holiday dvd then...i do hope not. Thanks again. -
Yes, of course they will. Demux the whole video with PGCDemux. Then redo the video portion however you like. When the time comes to reauthor it with Muxman don't forget to load the celltimes.txt (the chapters) in File->Import Chapters, and then after doing the 'Replace' step with VobBlanker, the chapters will be as they were before. If you change the length of the video by, for example, cutting out scenes, you might have trouble with the chapters, but you haven't said anything about doing that.
replace subtitle of blu-ray main file on tsmuxer 1.10.6 problem
By ps3z in forum Authoring (Blu-ray)Replies: 0Last Post: 8th May 2010, 15:02 -
Reauthor DVD movie file
By Trace in forum Authoring (DVD)Replies: 2Last Post: 24th Mar 2010, 20:45 -
Convert main movie from DVD to TS.
By Puni in forum Video ConversionReplies: 4Last Post: 19th Feb 2010, 08:42 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 04:37
