**Note: I'm a n00b lol.
I can't seem to get my Samurai Champloo file series to work when remuxing. I am trying to create a PS3 compatible .M2TS container. The original file is an .MKV container with:
When muxing with default settings, I encounter this error:
So I changed the settings to 23.976 fps, and tried it again. This worked, and functioned perfectly on my PC. However, when I tried it on my Playstation, it recognized no audio codec, and therefore had no sound. Additionally, the video would play very quickly as if it were in fast forward... but only on the PS3.
I also tried converting the AAC track to AC3 and then muxing with the video like this:
When I check the information of this file on the Playstation, it diplays both:
Video Codec: AVC 362 kbps
Audio Codec: Dolby Digital 128 kpbs
However when I play the file, it skips. For the first 5-6 seconds, the sound plays fine but there is a black screen, and then one or two frames from the video show up and skip. After a few more seconds, the audio starts to die as well, and 1 frame of both video and audio will play every few minutes. I can't seem to get this series to work!!!
Can somebody help me?? I have listed a download link underneath to the first episode of Samurai Champloo in the .mkv format I need help with.
(Don't worry. It's 90 megs and CLEAN XD)
http://www.2shared.com/video/LsmHhgNH/SC-01_Tempestuous_Temperaments.html
Results 1 to 1 of 1
MKV to M2TS w/ TSMuxer
By averageschmoe in forum Video ConversionReplies: 2Last Post: 22nd May 2011, 00:21 -
Subtitles stay too long when converting MKV to AVCHD for PS3 with tsMuxer
By WFlits in forum Video ConversionReplies: 5Last Post: 31st Oct 2010, 05:15 -
Can remux .mkv to .m2ts with tsMuxer but how to do the reverse?
By MilesAhead in forum Video ConversionReplies: 8Last Post: 22nd Apr 2010, 14:27 -
MKV avc to m2ts via tsMuxer;1080p muxing problem for ps3. Please
By rafoolik in forum Blu-ray RippingReplies: 5Last Post: 11th Aug 2009, 17:55 -
Problem converting mkv to m2ts (for PS3)
By scift in forum Video ConversionReplies: 8Last Post: 16th Dec 2008, 17:22
