Hello all.
Here is a thread I'm starting for discussions on my DV cam endeavers,
ie, problems, issues, current events like TV shows/movies to captures,
etc., etc. bla, bla,
So, I'm opening up the thread with a topic on tonights showing of TNT's
* "The Matrix". . .
The Matrix is on TNT and I want to tape it to miniDV too see what kind of quality I get from it. I heard there's a scene or two that is difficult to encode to. Is that the lobby scene, where there's a lot of gun fire and explosions ?? I'd like to mess around with them tonight, if time allows. And, are there any other scenes that others have. I tried encoding parts of Matrix a while back, but i had problems with my AVI captures, and other captures I needed to take priority of at that time. So, it was only brief.
Please let me know of any other scenes in "The Matrix" that you know of
that give you a hard time to encode (blocks)
So far, I have plans to test some captures off my NEW Apex AD-1500
after I macro-clean it, and I will see if my DV cam can capture from it
without shutting down, as in my previous attemps on my old model
AD-1500.
Why, so I can rule out the "color space" issue I'm having on some caps
from my DV can. I'm assuming that it's my Satalete signal for now.
If my AD-1500 works, and if the video is better, then at least I know what
is causing the "color space" issue. I'll be trying this tonight, if time allows,
or during the commericals.
Well, see yas in a bit.
-vhelp
There are quite a few scenes in this movie that are going to be quite difficult to encode, the lobby scene being one of the most notable examples. You will have best luck if you can use DVD as your source, since you would then have widescreen and film framerate to help save you bits, in addition to the cleaner source quality. Still, I would be interested to hear how it goes capturing it from TV.Originally Posted by vhelp
oops, LOL, I was miss informed about the Show's air date and time.
I guess I'll see what else is on.
oh, well. If any other shows come to mind...
-vhelp -
I posted this on another thread, so I'm basically repeating it case
you didn't view the other thread.
I finally got my ad-1500 to work w/out macrovision, and can NOW cap
from my ad-1500 to my DV cam. So, I did a capture of one of my
favorate movie's, "Dogma" since it's in great quality, and not too
many moving parts. Did a scene in the restoraurant and on the train.
Easy scenes here. anyways, I did some test encodes to SVCD and,
quality of SVCD is smooth, but the color was horrid!! It was on the
"brown" side!!. Really bad.
Yep!! There's definately a "color space" convergence going on here. I
think it's the DV's "driver codec" that's doing the convergence here, but
I could be wrong. Right now, there is not one person in knowedgeable
here on this forum that can explain it, AND give resolution/answer
to it. Would love to solve it. I think it's just a matter of figuring out how
to re-map the "color space" using filters in VD or TMPG, but TMPG doesn't
seem to be able to supply enough color filters for the job, nor VD. I think
that there must be a seporate, special "color space" converagence filter
for TMPG and/or VD to handle/fix this for us DV cam users.
Really, this clip's color was so bad. If any of you's want, i'll post a small
sample clip to demonstrate what I'm talking about, and those that HAVE a
legit copy at hand, can do a quick rip and encode of the same scene and
compare with mine. It's really bad.
* A definate bad point (thumbs down) on this issue for the DV cam's.
I will play around with the two test DV avi files I just did, for a little while
longer. If I find anything worth posting, I'll reply here.
-vhelp
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 19:35 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 14:42 -
Which Cam for your bucks?
By NautTboy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 1st Jan 2010, 23:44 -
HD Cam wrote .mts files to my flash card but put in another cam still mts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 07:15 -
video cam = $39
By zoobie in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Dec 2008, 17:14
