Is there any way to keep 4:3 aspect ratio when converting VIDEO_TS to MKV from Handbrake without converted to a lower resolution? Handbrake wants to reduce the resolution by default, which I'd rather not do. If I convert the file at 720 x 480 resolution it assumes 1:1 aspect ratio and stretches when I play it despite being the same resolution as the source VOB file.
non square pixels ; or aspect ratio information either at the stream level, or container level. The VOB has it flagged as 4:3, but your current MKV displays as square pixels , so 720/480 = 1.5 (which is wider than 4:3 or 1.333)
1) easiest way to fix, is the container level. In mkvtoolnix, highlight the video stream , format specific options tab, and set the aspect ratio to 4:3 and remux it
2) to encode it into the stream, you need to pass a --sar x:y command
NTSC 4:3 => sar 10:11 (or 8:9)
NTSC 16:9 => sar 40:33 (or 32:27)
PAL 4:3 => sar 12:11 (or 16:15)
PAL 16:9 => sar 16:11 (or 64:45)
the 1st values are based on 720width, the 2nd based on 704width (There is way more to this discussion about AR but you don't have to know the details, there are several threads on it if you want more information)
So you would use --sar 10:11 or --sar 8:9 on the command line if you wanted to encode it at the stream level -
It should be enabled by default (I don't think you can disable it unless you specify --threads manually in the commandline)
Open up taskmanager and you should see all your cores working
However, if you use certain single threaded filters or settings, they may impose a bottleneck - this means you will not get 100% usage
Encoded in Handbrake Aspect Ratio Incorrect in Roku
By douga in forum Video ConversionReplies: 7Last Post: 1st Jul 2011, 08:41 -
Correct Cropping/Aspect Ratio with Ripbot vs Handbrake
By Tony Jenkins in forum Blu-ray RippingReplies: 16Last Post: 20th Jun 2011, 17:47 -
HandBrake & aspect ratio change?
By neworldman in forum Video ConversionReplies: 1Last Post: 4th Jun 2010, 04:31 -
Aspect ratio confusion with .avi on standalone.
By Nocontact in forum Newbie / General discussionsReplies: 60Last Post: 15th Jan 2010, 14:54 -
resolution / pixel aspect ratio confusion
By greg0ry in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2007, 15:27
