Hi All,
I'm importing a .VOB file of my state high school game from 1986, into virtual dub to clean up the video, and for some odd reason virtual dub will not import, or playback the audio. I thought I could click on Auto->Conversion but its disable. How do I tell virtual dub to import/convert AC3 audio?
I also noticed that the video will not play back either when I click on play in Virtual Dub, but plays back on everything else.
The following is what is embedded in the VOB file.
ormat : MPEG-PS
File size : 943 MiB
Duration : 7s 715ms
Overall bit rate : 1 025 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=15
Duration : 7s 613ms
Bit rate mode : Variable
Bit rate : 1 005 Mbps
Nominal bit rate : 9 555 Kbps
Width : 704 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 99.192
Stream size : 912 MiB (97%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 7s 715ms
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Video delay : -67ms
Stream size : 241 KiB (0%)
Thanks.
AC3 to MP3 in AVI via Virtual Dub
By Simmons in forum AudioReplies: 7Last Post: 22nd May 2012, 19:16 -
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 15:03 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 18:47 -
No Video In Virtual Dub, Just Audio
By AllenM in forum EditingReplies: 11Last Post: 3rd Oct 2008, 14:35 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 20:45
