so u have to change ur password every 30 days?
Whether you have to change your password, and with what frequency, will be determined by an administrator.
I'm the computer admin, but i got pro cause me and 2 of my friends all pitched in to buy it.
how do i change it. -
Control Panel -> Performance & Maintenance -> Administrative Tools -> Computer Management.
Under "Local Users and Groups", select the "Users" folder. Right-click on Administrator, and select Properties. Check "Password never expires", and you'll only have to change it when you want to. -
Thank you.....
I was wondering this as well.
Previously I had found an option to set password expiry to a defined level so that went up to 999 but now I don't need to worry about it..
TYVM
Windows 7 Ultimate 64 - Intensity Pro 3.5.1
By XAM in forum Capturing and VCRReplies: 19Last Post: 14th Apr 2012, 07:19 -
VOB2MPG PRO v3 - Windows 7 Problem
By xtekm in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 1st Apr 2012, 10:00 -
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
Final Cut Pro on Windows?
By HoosierGuy in forum EditingReplies: 2Last Post: 17th Jun 2011, 22:18 -
Can QT Pro for Windows capture from TV Wonder?
By tedbragg in forum Capturing and VCRReplies: 0Last Post: 18th Dec 2007, 21:29
