Results 1 to 16 of 16
    May 2006
    United States Of America
    Hi all,
    Since it's obvious that you all know your "stuff" very well, I'd like some advice. Can you fill me in on which of the apps in this post are obsolete or just not "worth it"?
    Brace yourself... long-winded post:
    AutoGK - I really like this one, so I hope it's not looked down upon too badly.
    AviSynth - I'm just starting to learn how to use this and really like it as well.
    BeSweet - I have a feeling this might be looked down on at least a bit, but it's the only app I've tried that properly encodes 5.1 AC-3s... and believe me, I've tried a plethora of them.
    BSMUXWIZ - This is the only tool that creates MUX files that when fed into BeSweet will properly encode 5.1 AC-3s. It's definitely not anything to write home about, but it's all that works, at the moment.
    DGIndex - I don't know what your thoughts on this one might be.
    DVD Shrink - Used often and I like it.
    DVDFab - Love it.
    DVD-lab Pro - Despite not being good at using it, I like it.
    DVD2AVI - I haven't used this in ages and apparently don't need to...?
    FixVTS - Thoughts?
    FreeDVD - Thoughts?
    IfoEdit - Used to add some details that are occasionally left out of indie DVDs.
    Neat Video - Another one I really like and use from time to time.
    SmartRipper - Occasional use.
    TMPGEnc - Doesn't look outdated, but looks can be deceiving...?
    VirtualDub - Used all the time.
    VirtualDubMod - Used in conjunction with VirtualDub.
    VLC - I'd like this better if it would properly output 5.1 mixes. For some reason it only lets me choose Mono or Stereo. Other than that, I don't know why one would pay for DVD-playing software...?
    Thanks in advance,
    Justin
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    If a tool does the job you want, the way you want it done, and with satisfactory results, who cares how old or 'outdated' some may consider it to be?
    I still use a large number of the tools you mention. (Most, because I don't deal as much with DVD authoring.)
  3. Of the programs on your list I use AviSynth, DgIndex, DVD Fab, VirtualDub, and VLC pretty much every day. Occasionally VirtualDubmod, Neat Video, and TMPGEnc Plus (mostly just the muxing/demuxing tools).
    Other tools I use quite ofter are Mpg2Cut2, ImgBurn, MkvToolNix, Yamb, HcEnc, Bitrate Viewer, Audacity, MediaInfo, GSpot, GraphEdit, GraphStudio, MPCHC, ffdshow, xvid codec, HuffyYUV, Lagarith, Lame. Occasionally AviDemux, TsMuxer, h264TsCutter, KMplayer, AviFRate, DVD Decrypter, Subtitle Workshop, and Xvid4PSP.
  4. Out of all of those I use DVDShrink the most, second would be IfoEdit. VLC is now my favorite software player.
    As for SmartRipper that one is definately obsolete.
    Aug 2004
    I'd say dvd2avi is obsolete with dgindex taken its place.
    Dec 2010
    quebec
    i don't realy like vlc media player kinda jerky
    i prefer zoom player or media player classic
  7. i guess, tools never get obsolete, if purpose is fully served.
    just kidding....to have a smile on face......
    following bugger gave me ride and made it possible, while i was rushing to catch a flight and got stuck in a traffic jam near Leicester Square.
    May 2006
    That's my take on it, but I've been condescended to in the past for using some of these tools. Which is why I'm asking for your opinions
    May 2006
    Other tools I use quite ofter are MediaInfo, GSpot, xvid codec, HuffyYUV and Subtitle Workshop.
    Yeah, I was going to list those too, but I figured the list was already getting far too long. I prefer XviD to DivX, by far. However, I wasn't going to mention that, as it may start a war over which is "better". I also prefer Huffy to Lagarith. MediaInfo and GSpot are great for, well, the purposes of those apps. Sometimes I'll use the Subtitle Workshop when I see that the subtitles provided in a DVD are basically incorrect or important pieces of dialogue/actions are missing completely.
    May 2006
    Darn. I'll still use SmartRipper occasionally. Though, what I (obviously) despise is when it crashes
    May 2006
    Yeah, I can't recall the last time I actually used dvd2avi. This tells me that I must've become used to using other tools that surpass it
    May 2006
    Yep. VLC can be a bit buggy too. I still prefer to use my WinDVD.
  13. You know the saying... "If it ain't broke..."
    did they give you a reason? e.g. don't use this because.... or this tool is better because... x,y,z
    (I'm hoping I wasn't the "condescender")
    DVD Shrink on your list can be problematic (doesn' t work on newer movies & copy protections)
  14. Originally Posted by poisondeathray View Post
    True but's it still useful for combining discs and removing unwanted material, also when I don't feel like using a DL.
    May 2006
    Nope. They pretty much just said it's old, but didn't provide any reason not to use it anymore, nor did they recommend a newer utility... and no, you weren't the one condescending
    May 2006
    Well, luckily I've yet to run across a DVD that didn't work with DVD Shrink.
