I'm new to all this I have been using Slysoft to rip my DVD's down to put on hard drive to watch them with media players, but each movie takes a minimum of 4 GB. I would like to rip them down to mpeg 4 or xvid, or something that would take them down to a smaller size, but at the same time I want to keep them 16 x9 if possible with best sound possible. Everytime I do one it comes out high quality but smaller screen size. If I try to stretch screen size it loses quality. I don"t really understand the bitrate conversions and technical stuff. I do realize that most of the programs rip them down to play on portable devices.
So my question is can anyone explain to me or tell me what compression to choose and what settings to choose to get movies down to 2GB or less and still retain picture size and picture and sound quality. Or link me to post here that would explain it in converting for dummies terms.
Thanks Bill
I keep the same frame size as the DVD (cropping away any black borders) then encode as h.264 video with 16:9 flags. I keep the original AC3 audio. I usually use DgIndex, AviSynth, and the x264 CLI encoder. But you can do it more easily with a simple front like Xvid4PSP. Using one of the presets like "x264 Q21 DXVA HQ Film" will typically shrink you video down to 1/3 the VOB size without losing much quality. If you want higher quality you can customize the Q value or use one of the lower Q presets. The file will be larger but probably still significantly less than the VOBs.
MediaCoder x64 build 5175 video noise in DVD vob conversion
By ejai in forum Video ConversionReplies: 6Last Post: 21st Jul 2011, 20:12 -
VOB conversion help
By MarkL1986 in forum Video ConversionReplies: 4Last Post: 14th Feb 2011, 09:10 -
Conversion issues with with 1. vob-file of a ripped dvd
By NSmooch in forum Video ConversionReplies: 5Last Post: 8th Jan 2010, 01:55 -
VOB to DV conversion
By candy56 in forum ffmpegX general discussionReplies: 12Last Post: 28th Dec 2009, 23:53 -
AutoGK DVD to DivX, which VOB file to pick for the conversion
By rhythmofthecosmos in forum Newbie / General discussionsReplies: 2Last Post: 11th Apr 2008, 14:25
