    NYC
    Hello guys!
    Happy New Year to you all!
    I just built new PC and wanted to try and test it.
    Using as always DVDFab HD Decrypter, then DVD Shrink and finally ImgBurn. Burns without any problems, but I got an error Miscompare at LBA at Verification.
    I ve heard some of you said that Verify is not important, but it is somehow to me especially since I never had this problem before, except when I had found my previous faulty burner.
    Here is my ImgBurn log (hope its not too big):
    I 18:34:49 ImgBurn Version 2.5.5.0 started!
    I 18:34:49 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 3)
    I 18:34:49 Total Physical Memory: 3,601,728 KB - Available: 3,075,404 KB
    I 18:34:49 Initialising SPTI...
    I 18:34:49 Searching for SCSI / ATAPI devices...
    I 18:34:49 -> Drive 1 - Info: HL-DT-ST DVDRAM GH22NS50 TN02 (D (ATA)
    I 18:34:49 Found 1 DVD±RW/RAM!
    I 18:39:32 Operation Started!
    I 18:39:32 Building Image Tree...
    I 18:39:32 Checking Directory Depth...
    I 18:39:32 Calculating Totals...
    I 18:39:32 Preparing Image...
    I 18:39:32 Checking Path Length...
    I 18:39:32 Contents: 7 Files, 2 Folders
    I 18:39:32 Content Type: DVD Video
    I 18:39:32 Data Type: MODE1/2048
    I 18:39:32 File System(s): ISO9660, UDF (1.02)
    I 18:39:32 Volume Label: MOVIE
    I 18:39:32 IFO/BUP 32K Padding: Enabled
    I 18:39:32 Region Code: 1, 2, 3, 4, 5, 6
    I 18:39:32 TV System: NTSC
    I 18:39:32 Size: 2,703,947,776 bytes
    I 18:39:32 Sectors: 1,320,287
    I 18:39:32 Image Size: 2,704,572,416 bytes
    I 18:39:32 Image Sectors: 1,320,592
    I 18:39:32 Operation Successfully Completed! - Duration: 00:00:00
    I 18:39:47 Operation Started!
    I 18:39:47 Building Image Tree...
    I 18:39:47 Checking Directory Depth...
    I 18:39:47 Calculating Totals...
    I 18:39:47 Preparing Image...
    I 18:39:47 Checking Path Length...
    I 18:39:47 Contents: 7 Files, 2 Folders
    I 18:39:47 Content Type: DVD Video
    I 18:39:47 Data Type: MODE1/2048
    I 18:39:47 File System(s): ISO9660, UDF (1.02)
    I 18:39:47 Volume Label: MOVIE
    I 18:39:47 IFO/BUP 32K Padding: Enabled
    I 18:39:47 Region Code: 1, 2, 3, 4, 5, 6
    I 18:39:47 TV System: NTSC
    I 18:39:47 Size: 2,703,947,776 bytes
    I 18:39:47 Sectors: 1,320,287
    I 18:39:47 Image Size: 2,704,572,416 bytes
    I 18:39:47 Image Sectors: 1,320,592
    I 18:39:55 Operation Successfully Completed! - Duration: 00:00:07
    I 18:39:55 Operation Started!
    I 18:39:55 Source File: -==/\/[BUILD IMAGE]\/\==-
    I 18:39:55 Source File Sectors: 1,320,592 (MODE1/2048)
    I 18:39:55 Source File Size: 2,704,572,416 bytes
    I 18:39:55 Source File Volume Identifier: MOVIE
    I 18:39:55 Source File Volume Set Identifier: 3E2E94F700142684
    I 18:39:55 Source File Application Identifier: IMGBURN V2.5.5.0 - THE ULTIMATE IMAGE BURNER!
    I 18:39:55 Source File Implementation Identifier: ImgBurn
    I 18:39:55 Source File File System(s): ISO9660, UDF (1.02)
    I 18:39:55 Destination Device: [5:0:0] HL-DT-ST DVDRAM GH22NS50 TN02 (D (ATA)
    I 18:39:55 Destination Media Type: DVD+R (Disc ID: YUDEN000-T02-00) (Speeds: 4x, 8x)
    I 18:39:55 Destination Media Sectors: 2,295,104
    I 18:39:55 Write Mode: DVD
    I 18:39:55 Write Type: DAO
    I 18:39:55 Write Speed: MAX
    I 18:39:55 DVD+R Reserve Track: No
    I 18:39:55 Link Size: Auto
    I 18:39:55 Lock Volume: Yes
    I 18:39:55 Test Mode: No
    I 18:39:55 OPC: No
    I 18:39:55 BURN-Proof: Enabled
    I 18:39:55 Write Speed Successfully Set! - Effective: 11,079 KB/s (8x)
    I 18:39:55 Book Type Setting: DVD-ROM
    I 18:39:55 Filling Buffer... (40 MB)
    I 18:39:56 Writing LeadIn...
    I 18:40:23 Writing Session 1 of 1... (1 Track, LBA: 0 - 1320591)
    I 18:40:23 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 1320591)
    I 18:44:41 Synchronising Cache...
    I 18:44:42 Closing Track...
    I 18:44:45 Finalising Disc...
    I 18:45:13 Exporting Graph Data...
    I 18:45:13 Graph Data File: C:\Documents and Settings\USER\Application Data\ImgBurn\Graph Data Files\HL-DT-ST_DVDRAM_GH22NS50_TN02_FRIDAY-JANUARY-14-2011_6-39_PM_YUDEN000-T02-00_MAX.ibg
    I 18:45:13 Export Successfully Completed!
    I 18:45:13 Operation Successfully Completed! - Duration: 00:05:18
    I 18:45:13 Average Write Rate: 10,276 KB/s (7.4x) - Maximum Write Rate: 11,132 KB/s (8.0x)
    I 18:45:13 Cycling Tray before Verify...
    W 18:45:23 Waiting for device to become ready...
    I 18:45:36 Device Ready!
    I 18:45:38 Operation Started!
    I 18:45:38 Source Device: [5:0:0] HL-DT-ST DVDRAM GH22NS50 TN02 (D (ATA)
    I 18:45:38 Source Media Type: DVD+R (Book Type: DVD-ROM) (Disc ID: YUDEN000-T02-00) (Speeds: 4x, 8x)
    I 18:45:38 Image File: -==/\/[BUILD IMAGE]\/\==-
    I 18:45:38 Image File Sectors: 1,320,592 (MODE1/2048)
    I 18:45:38 Image File Size: 2,704,572,416 bytes
    I 18:45:38 Image File Volume Identifier: MOVIE
    I 18:45:38 Image File Volume Set Identifier: 3E2E94F700142684
    I 18:45:38 Image File Application Identifier: IMGBURN V2.5.5.0 - THE ULTIMATE IMAGE BURNER!
    I 18:45:38 Image File Implementation Identifier: ImgBurn
    I 18:45:38 Image File File System(s): ISO9660, UDF (1.02)
    I 18:45:38 Read Speed (Data/Audio): MAX / MAX
    I 18:45:38 Verifying Session 1 of 1... (1 Track, LBA: 0 - 1320591)
    I 18:45:38 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 1320591)
    W 18:51:00 Miscompare at LBA: 7136, Offset: 2, File: \VIDEO_TS\VTS_01_1.VOB
    W 18:51:00 Device: 0x00 (Empty Sector!)
    W 18:51:00 Image File: 0x01
    W 18:51:00 Total Errors in Sector: 1,934
    I 18:51:00 Verifying Sectors...
    W 18:51:02 Miscompare at LBA: 7137, Offset: 2, File: \VIDEO_TS\VTS_01_1.VOB
    W 18:51:02 Device: 0x00 (Empty Sector!)
    W 18:51:02 Image File: 0x01
    W 18:51:02 Total Errors in Sector: 1,963
    I 18:51:02 Verifying Sectors...
    W 18:51:04 Miscompare at LBA: 7138, Offset: 2, File: \VIDEO_TS\VTS_01_1.VOB
    W 18:51:04 Device: 0x00 (Empty Sector!)
    W 18:51:04 Image File: 0x01
    W 18:51:04 Total Errors in Sector: 1,963
    I 18:51:04 Verifying Sectors...
    W 18:51:04 Miscompare at LBA: 7139, Offset: 2, File: \VIDEO_TS\VTS_01_1.VOB
    W 18:51:05 Total Errors in Sector: 1,932
    I 18:51:05 Verifying Sectors...
    W 18:51:05 Miscompare at LBA: 7140, Offset: 2, File: \VIDEO_TS\VTS_01_1.VOB
    W 18:51:05 Device: 0x00 (Empty Sector!)
    W 18:51:05 Image File: 0x01
    W 18:51:05 Total Errors in Sector: 1,946
    I 18:51:17 Verifying Sectors...
    W 18:51:25 Miscompare at LBA: 7141, Offset: 2, File: \VIDEO_TS\VTS_01_1.VOB
    W 18:51:25 Device: 0x00 (Empty Sector!)
    W 18:51:25 Image File: 0x01
    W 18:51:25 Total Errors in Sector: 1,950
    I 18:51:25 Verifying Sectors...
    W 18:51:26 Miscompare at LBA: 7142, Offset: 2, File: \VIDEO_TS\VTS_01_1.VOB
    W 18:51:26 Device: 0x00 (Empty Sector!)
    W 18:51:26 Image File: 0x01
    W 18:51:26 Total Errors in Sector: 1,948
    I 18:51:26 Verifying Sectors...
    W 18:51:27 Miscompare at LBA: 7143, Offset: 2, File: \VIDEO_TS\VTS_01_1.VOB
    W 18:51:27 Device: 0x00 (Empty Sector!)
    W 18:51:27 Image File: 0x01
    W 18:51:27 Total Errors in Sector: 1,967
    I 18:51:27 Verifying Sectors...
    W 18:51:27 Miscompare at LBA: 7144, Offset: 2, File: \VIDEO_TS\VTS_01_1.VOB
    W 18:51:27 Total Errors in Sector: 1,944
    W 18:51:28 Miscompare at LBA: 7145, Offset: 2, File: \VIDEO_TS\VTS_01_1.VOB
    W 18:51:28 Device: 0x00 (Empty Sector!)
    W 18:51:28 Image File: 0x01
    W 18:51:28 Total Errors in Sector: 1,941
    I 18:51:29 Verifying Sectors...
    E 18:53:44 Miscompare at LBA: 7146, Offset: 2, File: \VIDEO_TS\VTS_01_1.VOB
    E 18:53:44 Device: 0x00 (Empty Sector!)
    E 18:53:44 Image File: 0x01
    E 18:53:44 Total Errors in Sector: 1,943
    E 18:53:44 Failed to Verify Sectors!
    I 18:53:44 Exporting Graph Data...
    I 18:53:44 Graph Data File: C:\Documents and Settings\USER\Application Data\ImgBurn\Graph Data Files\HL-DT-ST_DVDRAM_GH22NS50_TN02_FRIDAY-JANUARY-14-2011_6-39_PM_YUDEN000-T02-00_MAX.ibg
    I 18:53:44 Export Successfully Completed!
    E 18:53:44 Operation Failed! - Duration: 00:08:05
    I 18:53:44 Average Verify Rate: 29 KB/s (0.0x) - Maximum Verify Rate: 3,124 KB/s (2.3x)
    What possibly may cause this?
    Thank you in advance,
    taboo
