Greetings,
I am trying to locate a device to which 8 inputs of varying types can be connected, and have it output to 1 device for video and 2 devices for audio.
The inputs should be able to be either composite, s-video, component or HDMI for video, and either R/L stereo, coax digital or optical for audio. The outputs should be either component or HDMI for video, and either R/L stereo, coax digital or optical as outputs. The output needs to be able to do two at the same time. (ie, my TV only has R/L audio inputs, while my Receiver/Decoder has both coax digital and optical inputs)
If such a device exists, would someone please point me in the right direction? I've tried search after search and either find really cheap devices (less than $100USD) that support 3 or 4 inputs all same type, or I find super expensive devices ($2000USD or more) that accept multiple inputs and multiple outputs.
Is there something out there that meets the stated needs and is in the several hundred USD?
Thanks,
Kelly
Results 1 to 1 of 1
Video compression error: The source image format is not acceptable
By jh443 in forum Video ConversionReplies: 8Last Post: 25th Apr 2011, 21:56 -
video compression error: The source image format is not acceptable.
By cutepraba in forum Video ConversionReplies: 0Last Post: 12th Dec 2010, 10:21 -
Audio/Video Selector & Output Quality
By Tom Saurus in forum CapturingReplies: 1Last Post: 15th Sep 2010, 16:27 -
Open source video format conversion engine
By TrupsT in forum Video ConversionReplies: 2Last Post: 2nd Feb 2009, 07:32 -
No audio decompressor could be found to decompress the source audio format.
By rocky12 in forum AudioReplies: 3Last Post: 1st Sep 2008, 00:59
