  1. Hey, i used GOTSent to convert a .MVK 720p file to play on my xbox 360. I followed this tutoral http://www.digital-digest.com/articles/Xbox_360_MKV_Playback_Guide_page1.html and did everything to the letter.
    I plugged my usb in to my xbox 360 and loaded the file, great picture but no sound.
    I looked up on here for answers and found a link to a program called Popcorn MVK Audio converter, i followed the steps in this tutorial http://audioconverter.heartware.dk/Tutorial/ but all i get is
    "Skipping conversion - none of the audio tracks can be converted or the conversion has been disabled: Audio Track #1 of codec A_AC3 is not of a codec type that can be converted by AudioConverter.If you have no sound while playing back this file, try the "Re-sample AC3 audio tracks" option in the "&File" menu"
    Dont know what to do can some1 please help me, thanks
    Jun 2005
    Portugal
    try to pass it thru MKV2AC3 which is an alternative to Popcorn MVK Audio converter
    Full install, and then I suggest to use the defaults, don't change anything but the output folder
    just add the ORIGINAL MKV, select an empty working folder and hit START...just simple as that
  3. ok thanks, will giv it a go,
