hello
i need some help with a dvd file a downloaded. its a boxing match that seems to have all of the fight on it but the file says its only 30 seconds long, when i try to play it in windows media player the video plays for about 30 seconds skipping to a different clip each time. i know the full fight is on there because when i drag the seek button back a little bit, it starts from a differnt section of the fight..then starts skipping scenes again.
is there any way i can fix this file so i can watch it normally then put it on dvd.?
hope this makes sense.
cheers.
Closed Thread
before someone can help i'd suggest download mediainfo which tells you what's inside the selected dvd file install then right click on the video click mediainfo then go view> tree> then go file export go text select save location desktop and post what the program said is in it.
hope ive done this right.
General
CompleteName : C:\Users\New User\Downloads\Frazier vs Quarry 1.VOB
Format : MPEG-PS
FileSize/String : 518 MiB
Duration/String : 39s 332ms
OverallBitRate/String : 111 Mbps
Video
ID/String : 224 (0xE0)
Format : MPEG Video
Format_Version : Version 2
Format_Profile : Main@Main
Format_Settings_BVOP/String : Yes
Format_Settings_Matrix/String : Default
Format_Settings_GOP : M=3, N=15
Duration/String : 39s 297ms
BitRate_Mode/String : Variable
BitRate/String : 108 Mbps
BitRate_Nominal/String : 8 000 Kbps
Width/String : 720 pixels
Height/String : 480 pixels
DisplayAspectRatio/String : 4:3
FrameRate/String : 29.970 fps
Standard : NTSC
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Interlaced
ScanOrder/String : Top Field First
Compression_Mode/String : Lossy
Bits-(Pixel*Frame) : 10.435
StreamSize/String : 506 MiB (98%)
Audio
ID/String : 128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
BitRate_Mode/String : Constant
BitRate/String : 256 Kbps
Channel(s)/String : 2 channels
ChannelPositions : Front: L R
SamplingRate/String : 48.0 KHz
BitDepth/String : 16 bits
Video_Delay/String : -67ms
StreamSize/String : 1.20 MiB (0%)
Text
ID/String : 224 (0xE0)-DVD-2
Format : EIA-608
MuxingMode : DVD-Video
MuxingMode_MoreInfo : Muxed in Video #1
StreamSize/String : 0.00 Byte (0%)
Menu
One thread is enough. https://forum.videohelp.com/threads/330664-vob-file-help!?p=2048286#post2048286
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 01:56 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
burning a dvd from an .avi file and a .wmv file
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 07:06 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 06:02 -
how can I convert dvd file on my computer to avi or a different file
By brew in forum Video ConversionReplies: 3Last Post: 19th Nov 2007, 20:21
