Results 1 to 10 of 10
    Jan 2011
    england
    hello
    i need some help with a dvd file a downloaded. its a boxing match that seems to have all of the fight on it but the file says its only 30 seconds long, when i try to play it in windows media player the video plays for about 30 seconds skipping to a different clip each time. i know the full fight is on there because when i drag the seek button back a little bit, it starts from a differnt section of the fight..then starts skipping scenes again.
    is there any way i can fix this file so i can watch it normally then put it on dvd.?
    hope this makes sense.
    cheers.
  2. plain mpeg format(single file) or is it dvdfolder? and how big is the file all up?
    Jan 2011
    england
    yea its just a single file. no ts or ifo with it
    Jan 2011
    england
    sorry the file is 518 mb
  5. size? if it's a small size then it's probably corrupted cause there won't be a 4gig movie in a 5mb file.
    Jan 2011
    england
    its not a very long fight though. all of the fight seems to be on there it just plays for 30 seconds then scips through real quick..is there no way of sorting this?
  7. you can try remuxing but first I would try watching it in a few different players as some might not read it properly
    Jan 2011
    england
    i tryd burning it on my dvd software but it did the same as when i put it on the windows media player. whats remuxing and how do you do this?
    cheers
  9. try downloading mpg2cut2 prefferably portable version extract open now it'll be a bit confusing when looking at it but click file add file then file save this clip select a place to save....if it plays properly in that program then it'l save properly. As i'm unexperienced with most mpeg editing / fixing hopefully another member will help you.
