Page 2 of 2
FirstFirst 1 2
Results 31 to 34 of 34
  1. batchmux uses a bit bout 50% once muxman finishes so only with tools that use command prompt could it be UAC also some other guy had wavi crashing to http://www.sevenforums.com/software/86944-software-author-dvds.html
  2. trying this method The StackHash error occurs any time DEP is invoked and has an issue with whatever application you're trying to run (and there are several hundred out there that seem to give it fits).
    The error is related to Data Execution Prevention. Here's how 99 percent of Vista users can fix a StackHash failure. I'll walk you through it step by step:
    Method A:
    1. Open your Start menu and click Control Panel
    2. Browse to "System Maintenance" then "System"
    3. In the left panel, select "Advanced System Settings" from the available links
    4. You should now see the System Properties Window, which will have three sections. The top section is labeled "Performance" and has a "Settings" button. Click this button.
    5. Select the "Data Execution Prevention" tab.
    6. Select the option which reads "Turn on DEP for all programs and services except those I select"
    7. Use the "Browse" button to locate the executable file for the application you were trying to start when you received the StackHash error, and click Open to add it to your exceptions list.
    8. Click Apply or OK to commit your changes.
  3. doesn't work think DEP has got something to do with it maybe wavi not using memory correctly gonna use ffmpeg.
  4. I think the major problem is avstodvd detects -1000's of memory when the computer has plenty free and available would changing dgpulldown for xp comnpatibility mode or wavi xp compatibility mode work in cmd when avs calls it?
