I have full iso rips of some TV series that I would like to separate into separate files for each episode. I would like them not to be compressed to much and would like them to be .mvk or .avi or .iso again. What software do I need to make this happen? I tried HandBrake it only makes chapters doesn't separate the episodes in separate files.
Well I found out that I can do this with DVD Shrink. But it takes a long time. Is there any software that will select the whole dvd iso file and separate every episode automatically? I have over 400 episodes to do. Will take some time with DVD Shrink.
Have you tried converting the ISO format to standard DVD AUDIO_TS and VIDEO_TS folders? Within the VIDEO_TS folder there will be a bunch of VOB files - if you are lucky and it depends on how the original was authored, each VOB just might be one episode. If that is the case you can convert them to MPEG or at a pinch simply rename them .mpg. Then you can turn each ep into mkv or leave them as MPEG files... worth a try but you still have a lt of work ahead of you for 400 titles. Personally I would leave them as MPEG so that there is no more encoding will will result in loss of quality. Not sure if you realise that separating them into separate files won't "de-compress" them. What you have is what you have and any further processing will degrade what you presently have apart from stripping them out as MPEG files from the ISO.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Mount the ISO with VirtualCloneDrive and use MakeMKV on the resulting virtual disk. That will cut them up into episodes consisting of the original MPEG2 VOB repackaged in an MKV container. Then you can run these as a batch through HandBrake if you'd like to save space by encoding them AVC or h.264.
Wow thank you...That worked awesome. Alot faster and easier the DVD Shrink. I will just leave the .mkv files uncompressed at about 1gb a episode. Fine with me. -
neworldman, you might also try opening the iso file with fairusewizard and outputting to h264 or avi.
How to export from DV-NTSC to H.264 with one File, not separate A/V.
By hellyes0 in forum ffmpegX general discussionReplies: 4Last Post: 13th Nov 2009, 14:16 -
burning mkv file and separate srt file to play on dual layer disc
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 11:26 -
Trying to Join separate files into 1 file, then add 1 more file and burn
By futureBDburner in forum EditingReplies: 2Last Post: 11th May 2008, 03:50 -
Playing an avi with a separate sub file in MPC
By majax79 in forum Software PlayingReplies: 5Last Post: 31st Dec 2007, 11:05 -
How to use my separate subtitle file?
By php111 in forum SubtitleReplies: 4Last Post: 29th Sep 2007, 14:54
