    Jan 2011
    Australia
    Hey all, just bought a Mac (finally) and got this prog. I notice I have a watermark in the trial version. Will this remove after registration/donation etc? Assuming it will but need to confirm.
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    ffmpegX does not put watermarks in converted video.
    The trial version is fully functional excepted for the "SVCD>DVD" and "DVD>DVD4GB" tools, and is not time-limited.
    Exactly as mentioned on the website.
    Jan 2011
    Australia
    Thanks mate. i just noticed as I played back the converted video (from .MOD) that it had a 'div x' watermark bottom right corner.
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Perhaps the source file already had the watermark?
    Perhaps you have a QuickTime Decoder Component installed that is interfering? (Use Perian instead.)
