I have a bunch of avi files of of these home movies.
Should I burn them onto DVD-9, getting about 2 hours on each DVD? Or should I use something like multiAVCHD
to make Blu-Ray Disks?
I know Blu-Ray wont improve the quality, but will I be able to put more minutes of home movies on the
Blu-Ray? I thinking about costs also
Fred
http://www.kiva.org/about -
I used Windows Movie Maker and saved as DV-avi, which I think is not compressed.
So If I use MPEG2 to make a DVD, then I am not losing noticeable quality, right? Can I make a BD using
MPEG2 also, allowing me how many hours? -
Keep the DV-AVI files as your archive. Encoding further to MPeg2 or h.264 will lower quality but will be OK for playback.
If this DVD needs to play on a DVD player, you need to keep to MPeg2 DVD spec (e.g. max video bit rate 9800 Kb/s) but Blu-Ray players usually allow more (~16000 Kb/s max) if you want highest quality. But it sounds like you want more minutes over quality so experiment with lower bit rates or h.264 encoding. I'd suggest ~ 8000 Kb/s MPeg2 video + 224 Kb/s audio. That would get you 2hr 15 min on a DVDR-9 or ~ 6.7 hrs on a BD 25.
Don't over-compress shaky home camcorder material. It doesn't compress well. Deinterlace is highly destructive so keep to 720x480i. The player will handle deinterlace better.Recommends: Kiva.org - Loans that change lives.
This sounds like very good advice, consistent to what I have heard elsewhere, but not all put together. My "archive" is 1 TB full, I hate to back that up,
so I guess I will just keep the original tapes as backup for now.
My AVSINfo.exe is not working, when I try to run multiAVCHD, so I will have to read more about it and figure it out, Thanks much,
Now I need to see if buying one BD 25 is worth buying 3 DVDR-9s, and where to buy them from. I will check the forums.
Thanks,
Fred
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 04:35 -
how to rip a blu-ray movie to a blu-ray disc
By TURBOLENCIA in forum Blu-ray RippingReplies: 1Last Post: 25th Nov 2010, 17:40 -
convert non blu ray movie to blu ray disc???
By dalmar6677 in forum Authoring (Blu-ray)Replies: 2Last Post: 31st Aug 2010, 19:51 -
Worth it to re-author SD video from miniDV source to Blu-Ray?
By jg0001 in forum Authoring (Blu-ray)Replies: 5Last Post: 27th May 2010, 13:55 -
MiniDV to Blu-Ray video on DVD
By bowmah in forum Authoring (Blu-ray)Replies: 9Last Post: 26th May 2010, 02:52
